Question about Tricity Bendix TM220W Electric Dryer
How do I replace a drive belt on a tricity bendix tm220w
I need to know how the belt fits onto the motor
SOURCE: Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Posted on Feb 09, 2010
SOURCE: Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Posted on Apr 11, 2009
Illeagle
  • 525 Answers
SOURCE: belt route on tricity bendix 310 w tumble dryer
These links should help out.
http://www.affordableappliance.com/Tips/beltdiagrams.htm
http://www.affordableappliance.com/helpful.htm
Posted on Aug 31, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I am trying to fit a new belt to my Tricity Benix
There is a pulley to tension the belt that sits in a slot on the floor of the dryer. If you have the belt wrapped around both the motor and the pulley try going up and under the tensioner in the opposite direction. I've been on hundreds of house calls for this simple solution. Good luck, Dana P.S. You will have to hold the tensioner back in order to get the belt on, if you do not have to hold it back than you are going in the wrong direction. Also, one side of the belt is ribbed and not the other, make sure you've got the correct side down. Look at the motor wear marks on the old belt, that will tell you which side goes against the drum.
Posted on Sep 06, 2009
emissionwiz
  • 79186 Answers
SOURCE: fit belt on tricity bendix
need the model number of the dryer
Posted on Sep 13, 2010
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How do I replace belt
the best thing to do is look it up on the manual, or searching it on youtube.
Aug 05, 2011 | Tricity Bendix TM220W Electric Dryer
My dryer s motor runs and heats up but does not turn, I have looked for a belt but cannot see one
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Tricity Bendix TM220W Electric Dryer
Manual for bendix consorte DN550
Belt & Pulley drawing for Tricity Bendix TM220W Dryer
May 03, 2010 | Tricity Bendix Dryers
Fitting new drive belt to tricity bendix aw405
most have no ajustment little tip put belt round the largest wheel then on the motor spindle put a flat blade screwdriver and leaver the belt on if you can turn the drum this helps
Oct 06, 2008 | Washing Machines
I need to change the drive belt on a Tricity Bendix 1200 washing machine. I have got the top of and can see the hole at the bottom of the machine but can't reach where the belt fits.
the belt goes round the motor spindle at the bottom. tape belt to large pulley. tilt machine backwards and put belt over motor shaft and tape into position. start belt onto main pulley and turn it so belt eases on. it is a tight fit
Jul 22, 2008 | Washing Machines
Tricity Bendix TM220W Electric Dryer Logo
1,050 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
