Question about Canon Office Equipment & Supplies
Canon mp490 printer U162 ink is full
Ink has been replaced but apparently not recognized by printer
  • 2386 Answers
SOURCE: How to change Ink in the Canon Mp490 Printer?
Hello
You can get help from this video
Hope this helps, if so do rate the solution
Posted on Jan 05, 2011
  • 5603 Answers
SOURCE: Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
Posted on Sep 01, 2009
  • 1606 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
MacD7
  • 67 Answers
SOURCE: refilled ink cartridges on pixma mp490 ...will not print
I know this is frustrating. I am all for recycling and using refilled ink and laser toner cartridges. However, the manufacturers make most of their money from ink and toner sales. So, from time to time, they will encode or datecode cartridge chips. The only times I've been ale to get around this is by using at least one genuine OEM cartridge to trick the printer. If that does not work, try another et of refills, or you will have to use only OEMs.
Posted on May 02, 2010
Testimonial: "guru u da man. thnx"
SOURCE: i have a canon pixma mp490 all in one printer and
Constantly get paper jam message while there's no paper jammed.
Is there a solution for this problem?
starinthesky69@hotmail.com
Michael Odor
Posted on Jun 23, 2010
Replaced new color ink and getting a u162 error code on my cannon pixma mx340 wireless office all in one inkjet printer
he ink may have run out. Replacing the ink tank is recommended.U162
The Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press the Stop/Reset button for at least 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition.
NOTE
If the function for detecting the remaining ink level is disabled, the ink cartridge
in grey is displayed in the remaining ink volume screen on the LCD.
Feb 04, 2015 | Cannon Office Equipment & Supplies
What does it mean check ink u163 0f canon pixma 360
re filled inks have being installed that's why u get u163 or u162 error
try following to resolve yours error u163 or u162
  1. Turn off your printer and turn it on again.
  2. After the printer initializes, try to copy or print something. The error will appear again.
  3. When the error is displayed on the display panel of the printer, press and hold the STOP/RESET button and wait until it self restarts.
  4. Release the STOP/RESET button while the printer is restarting.
  5. Wait for a few seconds and the pending print jobs will commence.
Jul 22, 2014 | Canon Pixma MX360 Printer
Hw do I open the MP490 canon printo to replace ink
With the printer plugged in and turned on, lift the entire scanner unit; you can lift it from just above the paper tray. Make sure that there are no documents on the scanner glass or in the automatic document feeder (if present). There is a support on the right side of the unit that will hold the scanner unit in place that will engage.
The ink cartridge carrier will move to the install ink position. Then replace the cartridge(s) and lift up the scanner unit then press the support in towards the printer. Then lower the scanner unit to close the printer. Wait until the printer stops charging the ink system before printing.
I hope this helps.
Jun 14, 2012 | Canon MP490 InkJet Printer
Reset ink level mp490
Hi
Open the printer cover.
Remove the ink cartridges and then reinsert them.
Mar 01, 2012 | Canon MP490 InkJet Printer
How do I change my ink cartridge on my canon Pixma MP490?
Visit the link below and download the Manual
http://www.retrevo.com/support/Canon-MP490-Multifunction-Printers-manual/id/23498dj693/t/2/
Here you will find detailed instructions about changing ink cartridges.
Aug 01, 2011 | Computers & Internet
I have replaced the black in ink in my canon MP470 with a refilled ink cartdige but keep getting a U162 (the ink may have run out, please replace) error message. hoe do i get rid of this meesgae and get...
Pressing the OK button will allow you to continue to print. Since the cartridge has been refilled, the printer ink level monitoring function will not work
Mar 27, 2011 | Canon PIXMA MP470 All-in-One Printer
I have a canon pixma mp490 all in one printer and am out colored ink how do i switch it over to be just black and white prints
Michael Odor
Feb 04, 2010 | Canon MP490 InkJet Printer
Error u162?
Press and Hold the STOP/RESET button and wait until it self restart.
Release the STOP/RESET button when the printer is restarting
Dec 13, 2009 | Canon PIXMA MP130 All-In-One InkJet...
438 people viewed this question
old marine
old marine
