Question about Dell 1200MP DLP Projector
Fan replacement, Dell Projector 1200MP
Fan is on, smell of heat, no high level kick over. Display goes off, temp light comes on.
5 Suggested Answers
DR NITIN
  • 221 Answers
SOURCE: 1200MP DELL Projector flickering problem
You should not try it for yourself, Call a Professional instead.
Posted on Jun 26, 2008
SOURCE: I just replaced the lamp
I have had the same problem. When I unplugged the projector and plugged it back in about 5 secs. later, it seemed to work. Odd, but true.
Posted on Mar 16, 2009
ginko
  • 19396 Answers
SOURCE: dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Posted on Nov 09, 2009
  • 38 Answers
SOURCE: problem with my dell 1200mp projector
This is a very common problem with these projectors. The fans lock up and the units are out of warrenty. The fan you replace it with must be the exact same as the old one, even though it is the same as a 5$ computer fan. The processor will detect the non-dell fan and shutdown in the same way. I Havent been able to find any replacement fans that will work. I may be interested in buying your broken projector from you if you give up.
Email me at: nalexandrov251[A-T]gmail.com and we might be abe to work something out.
Posted on Dec 08, 2009
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Changed bulb on the 1200mp and when i turned it back on the bulb came on showed the dell logo and then the temp light came on after this the projector went into stand-by mode. when i restart it does the...
Just went through this issue with a 1200MP. The cause of the failure was a failing optical speed sensor on the color wheel assembly. It overheats and produces an invalid signal shortly after startup, causing the projector to shut down. The good news is that this is a $2 part. The bad news is that I wouldn't really call this a "DIY" repair unless you have the ability to unsolder and replace tiny surface-mount electronic components. You will also have to do extensive disassembly just to get at the part, which is buried inside the optical system. I am a professional electronics tech, and removing/replacing the part took me about 2 hours on a fully-equipped workbench. Troubleshooting the unit to FIND the failed part (without any service manual or schematic) took another couple hours, FWIW.
If you want to give it a try, the part you need is a GP2S27 "photointerrupter" manufactured by Sharp. These were discontinued a year or so ago, but some distributors still have stock (get them while you can). I got mine from DigiKey. This is a tiny little part about the size of a match head, with 4 terminals that need to be soldered onto a small circuit board, after removing the old part. You will need a steady hand, a fine-pointed soldering iron, and a magnifier with plenty of light.
Aug 22, 2011 | Dell 1200MP DLP Projector
I have a dell 3300MP projector. When starting up the Dell logo is displayed fine. After about 1 minute the unit goes to a solid amber temp light status. Projector display turns off. Unit shows...
Make sure the cooling fan is working and air is reaching the light source, you can hear it running (low whirling noise) when you turn it on, if not that is the problem.
Mar 17, 2017 | Dell 3300MP Multimedia Projector
Dell 1200MP works with PC but not the DVD player,
Hi.
Try the following:
Nov 09, 2009 | Dell 1200MP DLP Projector
My remote won't work on my Dell 1200 projector
remote wont click to next page on Powerpoint presentation
Mar 05, 2009 | Dell 1200MP DLP Projector
Problem with my dell 1200mp projector
if you haven't already try cleaninig the filters
Aug 22, 2008 | Dell 1100MP Multimedia Projector
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Jun 26, 2008 | Dell 1200MP DLP Projector
Dell 1200mp
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
May 06, 2008 | Dell 1200MP DLP Projector
Dell 1200MP DLP Projector Logo
89 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
