Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint aquarias is not emptying
Gone through cycle but fails to empty
Apparently somethinghas found it's way to your drain port, access thru back panel remove the fitting
Posted on Feb 11, 2012
  • 139 Answers
SOURCE: washer will not empty its water -hotpoint washer
Chec to see if the water pump is plugged with lint or some othe debris
Posted on Oct 14, 2009
  • 14 Answers
SOURCE: Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Posted on Dec 30, 2007
  • 1028 Answers
SOURCE: Hotpoint WF250-Loud banching when spinning
possible broken "spider"support on rear of basket best call serviceif unit is out of warranty be sure to ask for estimate first
Posted on May 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint wf220
If ther is no filter at the front of washer, then remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose, also remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Posted on Nov 15, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima WT965A fault code F08
To empty the washer, remove the drain hose from the outlet, and lay it down to floor level, this will let the water run out into a bucket or similar.
Code F08 is indicating means heater relay cann ot be activated.
Check all connectios to and from the pressure switch, the module, and the heater.
Hope this helps.
Posted on Jan 07, 2010
My Hotpoint Aquarius washing machine WMA58P will not empty.
Recheck your electrical connections. Check for power reaching the pump with a suitable tester. If there is no power then it might be the controller or that it might not be requesting the pump to operate.
Be patient...
Apr 17, 2017 | Hotpoint Washing Machines
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
My hotpoint wma74 front load washer makes a very loud thumping noise on the spin cycle ive got a feeling it could be the dampers but would like some more info please, ive run a the cycle empty and there...
It does sound as if at least one of your dampers are gone. Unplud the appliance from the wall, take the back cover off and see if there is any movement when you try shift the drum. If there is a lot of play on one side, that damper is likely gone.
Dec 12, 2010 | Hotpoint WMA74 Front Load Washer
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door latch broken on hotpoint wt761g washing machine. Machine has gone through wash cycle and emptied all the water, all lights have gone out but I can't open the door.
Depending on which part has gone, some hotpoints door trim post snaps which makes too much play not allowing door to open, in this case needs new door trim. others need drum to be empty of all Water, or could be door interlock faulty .give it a slight bang with your hand to ease open, remember has a 3 min delay on door....
Nov 20, 2009 | Washing Machines
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
