Question about Genica 54Mbps 802.11g Wireless USB 2.0 Network/Print Server - Share a USB Device Over Your Network (PRS301WUPB) Print Server
PRS301WU can't install
Cant create a port
Joey
If you have another (mac) pc available, you can create a USB key with your MAC OSx install disk. Put it in a USB port, and reboot. If there is no hardware malfunction, it will start the installer, and you can try to 'fix' the installation.
http://www.techrepublic.com/blog/apple-in-the-enterprise/how-to-create-a-bootable-usb-to-install-os-x/
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
How to install wireless router on windows 7
D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi-enabled devices in your home or office.
Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device.
D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment.
So there is no reason to wait around for a technician to help you install your wireless equipment.
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router.
Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router.
Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser.
Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field.
Click "OK" to open the wireless configuration page.
Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
hope this helps
Oct 10, 2012 | D-Link DIR-615 Wireless N 300 Router with...
Have an archos 7o tablet and cant remember password
You can create a Windows password reset disk to reset your password. Follow this 5 easy steps:
1. Enter a computer that can link to Internet. Search " Windows Password Recovery Tool 3.0 " in Google. Download and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset your password.
5. Now login Windows and set a new password.
Hope it can help you reset windows password.
Jun 22, 2012 | Computers & Internet
Cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Nov 19, 2011 | Bernina Artista 180
I have del all of my acer aspire one disk partitions and now i cant' create a new partition it show no hard drive. I Cant repair it with win7 setup disk it show no disk drive.... i can found c: drive...
Right click on My Computer, then click on Manage. A new window will open. In that window there is menu on left side pane. In that menu, find Disk Management and click on it. Now you see your hard disk along its partitions. Right click on any unpartitioned and select create partition. Now enter the drive letter and the amount of memory you want to allocate. Hope this helps you!!!
Aug 16, 2011 | Computers & Internet
Forerunner 305 "problem receiving activities"
I've had this problem. First -- and this sounds weird -- use a USB port on the back of your computer. Do NOT use a "secondary" type of USB port, such as an add-on hub, the ports on the front of a desktop machine, ports built into peripherals like a monitor, etc. Apparently, all USB ports are not created equal. Second, make sure you've the freshest Garmin Communicator plugin (which may entail a fresh download/install).
Apr 28, 2011 | Garmin Forerunner 305 GPS Receiver
Need instruction and advice on how to hard plumb my above ground pool.
You have to find out what are your suction ports (for example skimmer would be one you probably don't have a main drain)once you have all suction ports located pipe separately back to pump and create a manifold so that you can isolate each suction port with a valve on each line then tie all back into a single line then into suction side of pump then pipe return side of pump back to the return ports of pool installing a valve as you come out of pump you don't have to separate these lines.
Apr 11, 2011 | Plumbing
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
Genica 54Mbps 802.11g Wireless USB 2.0 Network/Print Server - Share a USB Device Over Your Network (PRS301WUPB) Print Server Logo
105 people viewed this question
Top Genica Computers & Internet Experts
David Payne
David Payne
Are you a Genica Computer and Internet Expert? Answer questions, earn points and help others
