Question about Toys
Lionel model train locomotive no. 8E e-unit diagram
Rewiring the e-unit
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
  • 5 Answers
SOURCE: locomotive won't come on
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
The value of a train set 1953 Locomotive 1130
A Lionel 1130 is a "Scout" type locomotive....they are not particularly valuable even to collectors. They were a part of the low end starter sets Lionel made. Now if you had a similar vintage 736 Berkshire or a 681 or 682 Turbine they are worth considerably more.
Aug 10, 2016 | Crafts & Hobbies
How to wire No. 165 Electromagetic crane
Service diagrams are available on the Lionel web site.
Jan 23, 2016 | Crafts & Hobbies
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
Lionel train problems
Check to be sure that the reverse unit is on. This may be a lever on the top of the locomotive or a slide switch under the engine. If that doesn't solve the problem, you will need to take the engine to a service center to be repaired. A list of service centers can be found at Lionel.com
Dec 20, 2013 | Crafts & Hobbies
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
On my Lionel Holiday Tradition Express the handheld remote works yet with the train will not respond. All connections have been cleaned and that is not the problem. I did notice that the wheels on the...
the train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Nov 28, 2010 | Lionel 11000 Holiday Tradition Express...
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Toys Logo
60 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
