Question about Sony VAIO FXA63 Notebook
Sony pcg-fxa63 need to retore the computer to all original factory settings, how can I do without reboot disk??
  • 807 Answers
You can buy recovery disks, here's just one place.
http://recovery-disks.com/sony-vaio-pcg-fxa63.html
$30.
Posted on Feb 12, 2012
Geekman
  • 32281 Answers
SOURCE: screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Posted on Jan 30, 2009
Bappa170873
  • 505 Answers
SOURCE: Sony Vaio pcg fxa63 cd/dvd drive broke. Where can
you can buy from any local tech shop or www.bestbuy.com
Posted on Mar 03, 2009
  • 30 Answers
SOURCE: how to reboot my sony vaio vgn-cs26t to original factory setting
insert the first recovery disk and simply reboot your computer. instead of loading windows you will be brought to a screen where you can set up your computer to be reformatted. if the computer boots windows instead you will need to change the boot order in the bios and set the cd rom drive first. this can be done by pressing a button or button combination while the computer is booting. pay attention because you onle have a few seconds. if all else fails call sony tech support and ask them how to change your boot order
Posted on Jul 23, 2009
  • 497 Answers
SOURCE: i need the original sony cd recover disk
From this link you can purchase the original Recovery Disk for your Computer.
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=A1090634A
If you do not want to purchase the Recovery Disk then you may use some search engine like Google to search the "Recovery Disk for PCG-K33".
Good Luck!!!!!!!!!
Posted on Oct 08, 2009
sonicboomele
  • 1557 Answers
SOURCE: I need to reboot my laptop to original factory
when the laptop boots up hit f10 and go into bios were it says load default settings click yes
Posted on Dec 01, 2010
How do i connect my sony vaio PCG-FXA63 to internet
Just plug in the network cable to the RJ-45 port. Reboot if you must.
Feb 01, 2013 | Sony VAIO FXA63 Notebook
Disk Access: Sense operation failed
Have tried to reboot it through its own internal memory w/out the discs? Restart your computer, get into your bios to go to factory restore and do it from there. You should be good to go from there w/out the discs. : )
Mar 28, 2010 | Sony VAIO PCG-Z1WAMP1 Notebook
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
My insprion 1525 does not have the repair computer option in the advance boot options...how can I reboot the hard drive to factory settings?
If you have the retore disk, this will be your best option. Not only will it restore your system but also put the recovery partition back on your hard drive.
Good Luck
C2Solutions
Jan 23, 2010 | Dell Inspiron 531s Desktop Computer
I need the original sony cd recover disk for my pcg-k33 sony laptop. i tried using another windows installer (MSDN), but it wont accept the product key. Sony says the laptop will only install windows from...
Good Luck!!!!!!!!!
Oct 05, 2009 | Sony VAIO PCG-K33 Notebook
Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Dec 04, 2008 | Sony VAIO PCG-TR3AP1 Notebook
PCG-9G1L SONY
not too sure what you mean here.you can reset bios to default or can set bios to factory reset.to set default ...when you turn on pc ,message at bottom left hand screen indicates which key to press to enter setup(bios setup) note...its very brief;mines f 10 for instance.at startup press this key and select load default then select save settings and exit;then ur pc restarts with default settings.
To reset bios to factory requires disassembly.
you locate rtc and remove battery(looks like large watch battery)for 5 minutes then replace,reassemble and restart pc.you dont need to know what rtc means(real time clock)or what it looks like cos the battery is right next to it.
Mar 04, 2008 | Sony VAIO FXA63 Notebook
Sony VAIO FXA63 Notebook Logo
145 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
