Question about Dewalt DC500 Canister Wet/Dry Vacuum
DeWalt DC500 wet/dry vacuum
Vacuum works on 120volt, but when just on battery the motor turns at extremely slow rev's and can barely hear it turning. ?????????
I had the same problem and traced it down to the on/off switch. I sprayed some electical contact cleaner down inside the switch and now it works normal. Hope this helps.
Posted on Nov 08, 2008
  • ubertabm Jan 25, 2009
    The electical contact cleaner ended up only being a temporary fix. I had to replace the on/off switch and that fixed it.
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
Why vacuum works for a few seconds only
Check the batteries with a voltmeter. Inspect the wiring for loose connecions or broken solder joints. Check the switch with a continuity tester.
Dewalt DEWALT Cordless/Corded Wet/Dry Vac 2 Gallon Vacuum: It was purchased new, and used only one time,the second time the unit was turned on it never worked and have never worked since, the motor and...
This vacuum has a history of problems with the battery contacts. Check that yours are not bent out of shape or corroded. if they are... straighten them or remove the corrosion.
Feb 18, 2010 | Dewalt Cordless/Corded Wet/Dry Vac 2...
My Dewalt dc500 only works on AC power (plugged in to wall socket). When you put in the battery it doesn't work. Can anyone help?
Check battery contactor on the vacuum and on the battery. It is a common problem on this vacuum. Check for bent pins and corrosion.
Jul 13, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
DeWalt DC500 Shop vac
the problem on your vacuum is the dc - dc converter.u cna replace them but to follow the same connection.
Oct 02, 2007 | Dewalt DC500 Canister Wet/Dry Vacuum
Dewalt DC500 Canister Wet/Dry Vacuum Logo
348 people viewed this question
Top Dewalt Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pcm2048
Are you a Dewalt Vacuum Expert? Answer questions, earn points and help others
