Question about Maytag Atlantis MAV6000 Top Load Washer
Water temperature problem
I have a problem with water temperature. It works fine on hot and warm, but continues to be warm even when just cold is selected. Seems the hot should be shut off and that is not happening. I have replaced both the temperature select switch and the water inlet valve, but the problem persists. Any ideas?
    President:
  • 878 Answers
Chief Walley, you have a temperature control board that sits right behind the timer. A thermistor senses the water and sends the info to this board. The thermistor sits at the water injector. The board may be your problem, I have seen many like this. Keep in mind that the target temp for cold is 75 degrees. If your incomming water is higher than this, you are going to get a warm fill, which they think is cold. Without being there, I would go after the board. Catriver...post back.
Posted on Aug 09, 2006
  • Gene Vaz Apr 28, 2013
    I am having somewhat of the same issue, when I select HOT only I get cold water runing in as well. Could the board you mentioned above be the same problem??
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Apr 01, 2009 | GE WBVH6240F Front Load Washer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
476 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
