Change sceen - Computers & Internet
  • 32,281 Answers
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Posted on Feb 12, 2012
My tv is set to wide sceen and is cutting off some of the picture. how do i set it to full sceen
You should have a setting in the menu's to change the picture size. May have to dig up the owners manual to find it though. I'm assuming the picture you do see is clear.
Jul 10, 2011 | Philips Magnavox 51MP392H Rear Projection...
Dear sir i was change my n73 nokia phone display but,display totaly blinking.how can solve that.please.
first you have to know change a sceen its not easy and maybe the sceen its not the right one
May 07, 2010 | Nokia N73 Cellular Phone
Blank sceen
ok
when u power up the computer press F8 key then u see safe mode and other menu then enter in enable vga mode then change screen resolution to 1024*768
May 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
PB on Imac sceen
I just looked at my System preferences, In the one for desktop, there is a little box that says 'change picture'. Make sure to un-check that box.
Mar 13, 2008 | Apple iMac G5 Desktop
BLACKBOX AT THE BOTTOM OF SCEEN
A text box is what you are seeing.....a function of closed-caption
feature...select CC and change until box goes out..........T.
Jan 16, 2008 | JVC AV-27D305 27" TV
Television picture gets larger
Your problem most likely is in your high voltage circuit, and the 160 volt radial lead capacitor is probably gone high ESR or changed in capacitence, this usually happens during bright sceens or sceen change.
May 24, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Seeing green du42px12x
I don't have a solution, but have a similar problem, when sceens change, red and green pixels form and create a burn in effect from the privious sceen. It happens after the TV has been on for at least an hour. I notice it most when goinf from a light to dark sceen. Any help would be great
Dec 24, 2006 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
