Question about Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual Speed Pump
Beachcomber 321 wireing daigrame - Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual Speed Pump
The light in our hot tub is not working..do you know how to install the new "clip" which we purchased from Beachcomber???
The light bulb just plugs into the fixture that is attached to the wires. Now, the fixture is installed from the back of the white niche by inserting it and giving it a quarter turn to the right. Next time you need a bulb, for a few extra dollars more you can upgrade to a color changing LED bulb. Find one at poolsupply1.com
Nov 01, 2014 | Pool & Spa
Fisher paykel wiring diagram
From my dealings with Fisher Paykel they do not produce wiring diagrams as all components lead into the main PCB
Apr 08, 2014 | Refrigerators
BEACHCOMBER HOT TUB NO DISPLAY
This could be failure of the display, the controller, or both.
Dec 12, 2013 | Jacuzzi Pool & Spa
Beachcomber hot tub
The only easy thing to check is that the thermostat probe is seated properly, and not hanging around measuring the outside air temp.
If the probe is somewhere where it is actually measuring the water, you can check the thermostat by turning it up and down. If you hear a relay clicking inside the control box, then the tub really does think that it is 56 (or whatever temp it clicks). If that is the case, it is the thermostat or just the sensor probe, depending on how old the tub is. If it has a temp probe that plugs in, then just change the probe (sensor). If it has a copper wire-looking thing connected to a copper bulb, then that is your t-stat and you need a new one.
Oct 26, 2013 | Pool & Spa
I want wiring daigram for 2fz engine
Go to auto zone .com open an account and sign in with your car click on repair manuals. It has all the wiring 40 pages or more
Dec 21, 2011 | 2001 Toyota Corolla
We have a 1997 or 1998 beachcomber hot tub, digital 3000 and the control panel seems to be locked on economy and we just can't get it unlocked. We've tried following the steps the instructions give us but...
I have a 1997 beachcomber tub w/ digital 3000 which was locked in economy and temp said 80*. i check solded joints and they were ok, i replaced the main board and it work fine now.
Jun 01, 2010 | Jacuzzi Pool & Spa
Need star delta control wiring daigram
49fb442.jpg STAR/DELTA MOTOR WIRING.
This is the wiring you need to follow.
Feb 11, 2010 | Siemens Seimens Arc Fault Breaker
I need a wiring daigram for subwoofer connection
Generally speaking most wiring set ups are the same for any sub and/or head unit.
Here is a diagram that you can refer to which has everything included, and if your just doing the sub to stereo you won't have to worry about the 4 channel amp in the middle or the speakers.
http://www.the12volt.com/installbay/uploads/amp_wiring_diagram.gif
Oct 18, 2009 | Sony Xplod (P589) Car Subwoofer
Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual Speed Pump Logo
97 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
