Question about Kitchen Appliances - Others
How to light pilot on pitco deep fryer - Kitchen Appliances - Others
  • 10 Answers
SOURCE: Light pilot on Royal deep fryer. Pilot will not
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Posted on Feb 06, 2010
burzerko
  • 254 Answers
SOURCE: fryer maybe leaking propane
Hello
To see if this is leaking you can make a soap solution of 1 tablespoon of dishwashing soap to 1 cup of water to see if it bubbles. Just apply it around the knob on the gas valve or pilot valve.If it bubbles it is leaking and will need replaced. This will rule out a draft of air coming from somewhere else.
Hope this helps
Posted on May 31, 2008
SOURCE: pitco fryer pilot out
the problem is the thermocouple , and not the gas valve or thermopile
Posted on Feb 12, 2009
bigg t
  • 640 Answers
SOURCE: soot coming from flu
Remove the burners and clean the burner orfices and baffles,also check the vent cap on the pressure regulator that sits on the back of the fryer.Let me know.
Posted on May 16, 2009
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
Hi there, Im wondering how to get a new pilot light part for my pitco fryer. Or will it take other brand Pilot lights? Cheers
It is usually best to use the same parts for the fryer but most of the time they are what you would call a generic part that is used by many. If you have a pilot that will fit it should work. But like I said it is best for optimum performance to use OEM parts or same model parts.
Oct 29, 2014 | Pitco Frialator SG18S Deep Fryer
Pitco fryer pilot light wont stay lite
The thermocouple is bad or the pilot light is not adjusted to heat the thermocouple to the point where the safety shut off stays on.
Jul 09, 2014 | Pitco Frialator 35CS Deep Fryer
Pitco fryer
Hi there!
Try to check first the incoming and running gas pressure, it must comply with the rating on the unit's nameplate.
Regards
Jan 26, 2013 | Pitco Frialator Kitchen Appliances -...
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
94 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
