Hafele mondo 2 carousel corner unit - Office Equipment & Supplies
    President:
  • 412 Answers
I'm not sure what your question is. Please re-post with more information about the model number you have questions about.
Posted on Feb 21, 2012
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
I'm not sure what your question is. Please re-post your question with more information about the projector model you have and specifics regarding your problem. Thanks!
Feb 11, 2012 | Office Equipment & Supplies
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
I hope this helps !!
Feb 14, 2011 | Kodak Carousel 4600 Slide Projector
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
HTH
Replacement belts and laser units are on ebay.
Nov 02, 2017 | Aiwa Audio Players & Recorders
Manually changing the toner
You can open the machine and use a pen or screwdriver to press the carousel release. Then rotate the carousel to access the cartridge to be swapped.
Aug 12, 2009 | Konica Minolta magicolor 2430 DL Laser...
Sony CDP-CX300 How To Replace Drive Belts?
The Sony call center says the two belts are the same size. Supposedly, there is a third belt "under the motor board" but I have not been able to find it. That is the 42x1.2 (4219362601). The two easy ones to replace are 421606101 and only cost 1.95 from Sony.
Aug 08, 2009 | Sony Audio Players & Recorders
Where to buy a hafele keying kit???
Check ebay and your locksmith
Jul 31, 2009 | Locks & Locksmithing
You can order a new carousel from Capresso. It's $90, though:
http://www.capresso.com/pdf/order-ultima.pdf
Make sure the lever is up when turning the carousel, and keep the button at the back of the machine depressed while screwing the carousel onto the unit (and while taking it off the unit). I think the positioning of the button point at the beginning of the carousel replacement process is also important:
http://capresso.com/pdf/inst_esp_ultima.pdf
Mar 28, 2009 | Jura Capresso Ultima 121 Espresso Machine
131 people viewed this question
k24674
jasbo
jasbo
