Question about Magic Chef 31000 Gas Kitchen Range
Range Top Pilot Lights
When the pilot light goes out on the 31000PAW models, will gas continue to come in and cause a dangerous situation?
  • Anonymous Nov 22, 2008
    I have the same problem and now I am afraid to light the pilot light - first of all it is way in the back instead of the front and I can't even see where you light it.
    President:
  • Magic Chef Master
  • 2,651 Answers
Use a bar-b-que lighter with a loing handle to lite pilot, and yes if the pilot goes out there will be a constant supply of gas going inot home, very minimal amount but as a cumiltve effect not very smart thing.
Posted on Nov 25, 2008
Burner won't come on or shut off have to manually hold contact open
On some gas-powered appliances -- such as gas ranges, water heaters, boilers and gas fireplaces -- the pilot light works to ignite the main flame when the gas is switched on to the burner by the regulating valve. If the pilot light is not lit, the gas burner will not ignite, which could cause a dangerous situation by letting highly flammable gas escape into the air. If the pilot light goes out, you can relight it after the gas is shut off using a match or the unit's electronic ignitor if it has one, following the proper safety precautions
Nov 12, 2017 | Heating & Cooling
I need to know how to light the oven? Does it have a pilot light like the stove top
most stoves do not have pilot lights but work from a pizo ignition system
when you turn on the gas knob ,the first action is to energize the pizo and that continually sparks to ignite the gas at the hob
the same is with the oven
ovens should be lit with the oven door open and once lit then the door can be closed
Jun 07, 2015 | Sears 61301 Gas Kitchen Range
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
I have a ventless gas heater. the pilot lights
It just has a little dust in the pilot safety and that makes it think low oxygen levels are present. Ti correct that situation I flush the pilot safety device with rust buster, I relight the heater with pretty good success. I have a page which shows where to clean and has a nice demo which shows exactly how it works HERE
Feb 28, 2010 | Heating & Cooling
One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Feb 23, 2010 | Vulcan Kitchen Ranges
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot light on GE oven, less than 8 years old keeps going out
the pilot and burner are usually covered, so it's doubtful that grease buildup would be a problem. it's probable that the thermocouple is defective or not positioned in the flame properly. the thermocouple tells the gas valve that there is a flame and it's okay to send gas through and the oven lights. if the t-couple is bad, it's fairly cheap to replace. however, if you could smell the gas odor from downstairs, the gas valve itself could be bad and that is not cheap to replace. get a competent repairman to check it out and turn off the gas while your'e waiting. you could have an explosive situation.
Aug 16, 2009 | Garland H283 Gas Kitchen Range
How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
Apr 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
234 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
