Question about Conair Vacuums
How to clean the head of the conair spin brush
Hot air spin brush
2 Suggested Answers
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: brush inside main head doesn't spin, and stops
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 12, 2011
    Should hot air come out of hepa filter on shark navigator. Brush spins have suction cannot find clog
    Yes the air coming out should be warm to hot depending on how long the unit has been running..Clogs are usually in the hose / pipe
    Something caught sideways or a piece of paper
    Sep 10, 2017 | Shark Vacuums
    Why beter bar dosent spin while in the vaccum mode only in up right position ?
    Hello! The air pressure from the motor is most likely spinning the brushes in the upright position. This vacuum has a brush-roll on/off pedal located on the left side of the cleaner. To activate the brushes, power the vacuum on, recline the handle and then press the brush-roll on/off pedal. The brushes should begin to spin. If they do not the belt may need to be replaced. Hope this helps!
    Jul 12, 2014 | Hoover Vacuums
    Miele brush bar not spinning
    Either the touchpad is defective, or the motor is bad.
    May 11, 2012 | Miele Vacuums
    Zip brush won't spin and I can't figure out how to fix
    did you check to make sure theres no clog in the hose since its powered by air?
    Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
    The brush bar will not spin. The belts melt when I turn it on and the belt drive is hot to touch with smoke coming out.
    The belt is rubbing the foot plate.Check to see if the foot plate is damaged.Allso check the bearings in the brush bar are free and spin without the belt on.If you cant spin the brush bar by hand with the belt not attached then your bearings are seized.Get a new brush bar
    Dec 30, 2010 | Bissell Vacuums
    The spinscrub brushes won't spin when any pressure is applied to the machine. What is the reason for this?
    There is an air inlet screen behind the brush indicator....if this is plugged with hair and debris, this will cause the brushes to stop spinning....also, if the mackine is upright or if the recovery tank is not in place, then the brushes will not spin.
    Oct 16, 2009 | Hoover F5906-900 Upright Steam Vacuum
    Hoover f5915
    Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
    Brushes should spin once you reassemble and power it up!!
    Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
    Brush spin,good suction at hose, no suction at
    Air passage from back of brush head, through the joint, and up to bag, may be blocked.
    Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
    Brush on my hoover f5515 stopped spinning
    Flat belt may be worn and loose or broken. String, hair, etc. maybe caught up on roller.
    Oct 27, 2007 | Hoover F5515 Hot Spot Upright Vacuum
    Brushes not spinning after change out
    I got my brushes spinning by moving them while the unit was running. For mine it seems that they got stuck from sitting. The brushes move from the air driven motor unit. This works from the vacumm that is being put through the machine. I just spun the brushes while the unit was turned on. Don't get your fingers caught.
    Oct 26, 2007 | Hoover F5906-900 Upright Steam Vacuum
    Vacuums Logo
    Top Conair Vacuums Experts
    JoeVacs
    Are you a Conair Vacuum Expert? Answer questions, earn points and help others
