Question about Weiser Lock Powerbolt 1000 Lock
Installed powerboat 1000 when I test lock motor does not engage?????
Please help
  • 963 Answers
Since your question is somewhat cryptic, I urge you to contact Weiser Customer Support directly.
Here is there contact page, which depends on where you live:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Good luck.
Posted on Feb 24, 2012
How Can a fan belt tensioner malfuction keep a motor from moving ?
Can you turn the engine by hand to make sure the engine isn't seized or hydrostatic lock? If you suspect hydrostatic lock, remove the spark plugs, then see if it will crank.
I don't know if you can visually inspect that the starter drive gear is engaging the flywheel? I can't see much from here, only make suggestions.
Dec 27, 2015 | 2000 Ford Windstar
1977 sportster xlh 1000 starter
Hi Anonymous, it sounds the like starter drive/clutch has gone south, it has components inside, that when spinning, centrifugal forces cause them to grab or lock into permanently fixed counterparts. The gear only spins one way and locks the other way. If you have one that spins both ways it has failed and needs to be replaced. Please visit the web site below for more help and good luck. Harley Davidson Manuals Mark Workshop
Oct 24, 2013 | 1979 Harley Davidson XLH 1000 Sportster
When is the next United States Powerboat Show?
Unfortunately, you just missed this year's show - it was held on October 13th. Check out the following link to find info about this year's show and to learn more about next year's show when in becomes available:
http://www.usboat.com/us-powerboat-show/special-events
Oct 16, 2013 | Boating
How much does a Nordic powerboat cost?
My friend just bought one and is very happy with it.
New Nordic powerboats usually cost around 150-250k.
A used one can go for 60-90k.
What is the difference between a powerboat and a jet ski?
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Jan 17, 2013 | Boating
We have recently installed this lock, the key works to unlock and lock the door but the keypad function does not turn the cylinder , we hear the motor working, trying to unlock/lock, but the cylinder is...
As long as you can hear it trying to engage the lock I would say that you need to adjust the strike plate in the door frame for a more precise fit' You can use your key to lock the door and see if you feel any rough spots when it is engaging the strike plate.One easy way to tell where it is hitting if you can't see it is to use a magic marker and mark the strike plate. Try to close the lock with the keypad after the ink has dried. If it is hitting the strike plate it should leave a mark in the ink so you know which way you need to adjust the plate.. You can either move the entire strike plate or you can use a rat tail or round file to make it fit. If you have a dremel tool they work well with a metal circular file bit.Hope this helps you. Thanks.
Aug 17, 2011 | Weiser Lock Powerbolt 1000 Lock
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Whirlpool self clean GGP84803 door won't lock when initialized.It is clicking and diplays locked but I can still open door?
If the lock will not engage and keeps locking and unlocking then turn the power off, slide the stove out to obtain access to its back. Remove the 3 screws from back cover and you will see the locking motor and a switch with a lever that rests on the locking rod. This lever has lost its firmness and does not engage the switch to tell the motor it is locked. Simply take a pair of pliers and bend the lever down to put more load on the lever. Now when the rod turns it will fully engage the switch which will tell the motor that the door is locked. Test your setting to make sure you have it adjusted right and then re-install your cover and push your stove back into position and enjoy your day. Takes 10 to 15 minutes and is cheaper than calling a service tech. Remember to turn the power off when working on the back of the stove through testing and such. No need to get hurt.
Jul 02, 2010 | Whirlpool Ovens
Error 08,045,43:42128
Hi Here are some codes for you
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All Best: Pineworks
Jan 04, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 first page blurry
  • Tray 1 status:
08.055.44:
37,008.44:
05,002.42:
assembly.
Aug 26, 2009 | Xerox Phaser 8400 Laser Printer
Weiser Lock Powerbolt 1000 Lock Logo
91 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
