Question about Monarch ® Attacher Gun for SG Tag Attacher Kit
Install needle so that it does not fly out when handle is pressed
I have a Pfaff Creative 1473 and am having problems with needle position.
Hello Eelee
As long as the display indicates the change, the needle will move. The needle is not moving with pressing the needle position button because the needle is too close to the fabric .... if the needle is raise up by turning the fly wheel, it will then move according to the number indicated on the display for needle position.
Please let me know how it goes.
Happy Stitching.
Mar 11, 2017 | PfaFF Sewing Machines
Needle not picking up bobbin thread and it makes funny loud noise
Sometimes both symptoms are a result of a bent, dull, or damaged needle. Try installing a brand new needle.
If it is still not picking up the bobbin thread and making a noise, take it for service. It most likely has a needle/hook timing issue and the noise could be the needle making contact with the needleplate or in the bobbin area. Continued use could cause the needle to break and flying pieces of needle, in most cases, are not a good thing.
Jun 18, 2016 | Brother Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Which needle do I need
Depends on the machine but most take universal needles, ball point for strechy/Jersey fabric, there's a denim needle for heavy duty fabrics that's xtra sharp. Any brand will work on all major machines with low shank. I'm guessing that's what your asking?
Dec 30, 2015 | Sewing Machines
Needle hitting needle plate
Needle is bent or installed improperly.
After breaking a needle I cannot get my bobbin to catch. also can't find the piece of needle.
you may have knocked it out of time just a little . repair shops do not charge much to retime usually .
Oct 19, 2015 | Sewing Machines
The starter cord has snapped. Can it be replaced?
Yes.Go to a harware store they or at least most sell the cord you need in bulk.Keep the handle as you will need it.Remove the fly wheel cover and the cord attaches to the fly wheel.Tie a knot in one end of the cord and slip it through the handle.Thread it through the hole in the fly wheel cover.Then just wrap it around the fly wheel.Reattach the cover,and you are done.
Jul 09, 2011 | Briggs & Stratton Garden
How do remove the window crank so i can remove the door panel?
There is a little clip behind the crank where it goes thru the panel. the clip looks like a "C" shaped clip..you'll need a small pick or screwdriver to pop it out..there is a tool specially made for this and can be rented fron autozone...once the clip is off crank pulls right off...when re-installing..put clip back on the crank , place crank over shaft, and press on till you hear it click.......ps..be careful as to not lose the clip...it's spring loaded and may go flying when you pop it off...if you do lose it they are readily available
Jan 20, 2011 | 1994 Buick Skylark
Fly fusion
I just had this same problem, and the Fly Fusion website has this to offer (the website link is http://fly.custhelp.com/cgi-bin/fly.cfg/php/enduser/std_adp.php?p_faqid=1619&p_created=1201901554&p_sid=fj7lBboj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD04NSw4NSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1 or you can go to Fly Fusion supprot link and click on the FAQ section to access this information):
Question Unable to install FLY World on Vista trnsp.gif Answer If you are unable to install FLY World on the Vista operating system, please follow these instructions.
1. In windows explorer navigate to c:\windows\system32
2. Find the application named "cmd". Now right click on "cmd" and select "Run as Administrator"
3. In the following window, type or copy and paste
regsvr32 /u vbscript.dll
Now press enter. You may receive a pop-up regarding DllUnregisterServer that it succeeded or failed. In either case, click OK.
4. Next type or copy and paste
regsvr32 /u jscript.dll
Now press enter. You may receive the same pop-ups regarding the DllUnregisterServer message. Click OK once more.
5. We will next need to type or copy and paste
regsvr32 vbscript.dll
and press enter. You may once again receive the pop-up window. Simply click OK to continue.
6. Finally, type or copy and paste
regsvr32 jscript.dll
7. Try running the installer again.
Jun 05, 2008 | LeapFrog FLY Fusion Pentop Computer
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
Monarch ® Attacher Gun for SG Tag Attacher Kit Logo
87 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
ka4iup
ka4iup
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
