Question about Brother DCP-585cw All-in-One Wireless Color Inkjet Printer
Dcp585cw opstartprobleem 5A
Opstartprobleem 5a
4 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: Unable to print and showing an 'unable to print 5A code
There are diffrent reasons for this error:
check, if something sticks in the machine (paper or metal clip)
The paperfeeder clutch gear is broken: check if the paper feeder works well.
The purge station has problems to do the cleaning jobs: gear broken or too much ink within the purge tubes.
Anyway, this problem is hard to handle for a novice due to so many diffrent reasons.
You should contact a service dealer and in case it is still in warranty let fix them.
Posted on Mar 06, 2008
SOURCE: problem printing unable to print 5A will not go away
Hello we went into the internet and they are all Junk from what we see.We had a MFC-4420C Before and it has a code 41 and all brother does is keep sending you refurbished printers back and forth so you have no warranty at all the warranty starts at the time you buy the first one so that is what happens.So beware anyone with Brother printers with these models. They are both Junk and you will just lose your money.
Posted on Jul 01, 2008
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
I need a schematic for the fuses on a 2002 VW Beetle. can you help me?
1 - Heated washer nozzles, heated outside mirrors 10A
2 - Turn signal system 10A
3 - Illumination 5A
4 - License plate light 5A
5 - Comfort system 7.5A
6 - Central locking system 5A
7 - Back-up lights 10A
8 - Telephone system 5A
9 - ABS 5A
10 - Engine control, gasoline 10A
11 - Instrument cluster, shift lock 5A
12 - B+ (battery positive voltage) for DLC 7.5A
13 - Brake lights 10A
14 - Interior lights, with central locking 10A
- Interior lights, only 5A
15 - Instrument cluster, automatic transmission 5A
16 - A/C-clutch, electrical water pump 10A
17 - Door lock heater 7.5A
18 - Right headlight, high beam 10A
19 - Left headlight, high beam 10A
20 - Right headlight, low beam 15A
21 - Left headlight, low beam 15A
22 - Sidemarker lights, right 5A
23 - Sidemarker lights, left 5A
24 - Wiper system, washer pump 20A
25 - Fresh air blower, air conditioning 25A
26 - Rear window defogger 25A
27 - Daytime running lights 10A
28 - Fuel pump (FP) 15A
29 - Engine control, gasoline 15A
- Engine control, diesel 10A
30 - Sunroof 20A
31 - Automatic transmission 20A
32 - Engine control, injectors, gasoline 10A
- Engine control, injectors, diesel 15A
33 - Headlight washer system 20A
34 - Engine control 10A
35 - Trailer socket 30A
36 - Fog lights 15A
37 - Radio system 10A
38 - Luggage compartment light, central locking system 15A
39 - Emergency flasher system 15A
40 - Dual horn 20A
41 - Cigarette lighter, 12V power outlets 15A
42 - Radio system 25A
43 - Engine control 10A
44 - Heated seats 15A
Mar 18, 2017 | 2002 Volkswagen New Beetle
2002 f150 power window fuse location
I looked at info for 02 f150 4.6L not supercrew. I saw two fuses, battery junction block, under the hood.
Mar 11, 2016 | Cars & Trucks
Where is the rear window defrost fuse located and what color is it for a 2006 Ford Taurus?
A combination fuse and circuit breaker panel (called the fuse junction panel) and is under the steering column. Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 - - Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 - - Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 - - Battery Saver Relay 35 - - Driver Unlock Relay 36 - - Rear Defrost Relay 37 - - Interior Lamp Relay 38 - - Driver Power Window Relay (One Touch Down) 39 - - Accessory Delay Relay Since rear defrost is a relay, not a fuse, you're looking for a big black square that plugs into the board with three prongs. If it rattles when you shake it, it's probably bad.
Oct 24, 2013 | COATES HEATER FUSE F3 SC30 30A480V...
Touran 2004 TDi Fuse layout
Here it is:
The fuse box diagram for 2005 VW Touran
Fuse box / relay plate, fascia 1:
1. F1 (5A) = Interior rear view mirror
2. F2 (5A) = Trailer socket
3. F3 (5A) = Heater / Air Conditioning (A/C)
4. F4 (5A) = Fuel lift pump control module
5. F5 (5A) = Heated front seats
6. F6 -
7. F7 (5A) = Heated front seats, heater / Air Conditioning (A/C)
8. F8 (5A) = Heated windscreen washers jets
9. F9 (5A) = Airbag
10. F10 (5A) = Telephone
11. F11 (10A) = Power steering
12. F12 (5A) = Automatic transmission (AT)
13. F13 (10A) = Headlamp adjustment
14. F14 (10A) = Anti-lock brake system (ABS)
15. F15 (5A) = Data link connector (DLC), reversing lamps
16. F16 (5A) = Databus cooection
17. F17 -
18. F80 (5A) = Emergency vehicles
19. F19 (5A) = Emergency vehicles
20. F20 (10A) = Parking aid control module
21. F21 (5A) = Automatic transmission (AT)
22. F22 (5A) = Auxiliary heater
23. F23 (10A) = Stop lamps
24. F24 (10A) = Auxiliary heater, Data link connector (DLC), heater / Air Conditioning (A/C), light switch
25. F25 -
26. F26 (10A) = Engine management
27. F27 -
28. F28 (5A) = Light switch
29. F29 (15A) = Rear screen wiper motor
30. F30 -
31. F31 (15A) = Auxiliary heater
32. F32 (15A) = Windscreen washers
33. F33 (10A) = Emergency vehicles
34. F34 -
35. F35 (10A/40A) = Heater / Air Conditioning (A/C)
36. F36 (10A) = Emergency vehicles
37. F37 -
38. F38 -
39. F39 -
40. F40 (20A) = Trailer socket
41. F41 (20A) = Trailer socket
42. F42 (15A) = Auxiliary power socket
43. F43 (15A) -
44. F44 (5A) = Alarm system
45. F45 (5A) = Audio system
46. F46 (5A) = Multifunction control module 1
47. F47 (25A) = Cigarette lighter
48. F48 (20A) = Headlamp wash / wipe system
49. F49 (10A) = Door function control module driver + passenger
50. F50 (30A) = Heated front seats
51. F51 (20A) = Sunroof
52. F52 (25A) = Multifunction control module 1, auxiliary heater
53. F53 (25A) = Multifunction control module 2
54. F54 (5A) = Automatic transmission (AT)
55. F55 (5A) = Emergency vehicles
56. F56 (15A/40A) = Heater / Air Conditioning (A/C)
57. F57 (30A) = Door function control module driver + passenger
58. F58 (30A) = Door function control module left + right rear
Audi Performance Chip
Aug 23, 2012 | Toys
How do i find fuse 3ag-5a?
this is a - large fuse type - all car spare parts carry this fuse
You need a large - 3ag - 5a = 5 amp fuse
3ag-5a = 3ag (large fuse ) 5a - 5amp
Dec 20, 2010 | AudioSource AMP-100 2-Channel Amplifier
Fuse box diagram for 2002 ford taurus
The 1999 Fuse Box Diagram is as follows:
Column 1 (Top to Bottom)
Driver Window Relay
Interior Lamp Relay
Driver Unlock Relay
Battery Saver Relay
Hazard Lamps (15A)
Diagnos (10A)
Cigar (20A)
Front Wipers (30A)
Air Bag (5A)
ABS (10A)
Shift Interlock (5A)
Blank
Column 2 (Top to Bottom)
High Beams (15A)
Deck Lid Release (15A)
Mirrors/Antenna (5A)
Head Lamp Illumenation (5A)
Light Out Module (5A)
EEC Ignition Coil (20A)
Brake Lamps/ A/C (15A)
Instrument Illumenation (5A)
Column 3 (Top to Bottom)
Accessorty Delay Relay
Rear Defrost Relay
Tail Lamps (5A)
Battery Saver (10A)
Wiper and Vaps (5A)
Rear Wiper (15A)
Turn Signal (10A)
Air bag/ Alt LPS (A)
Starter Relay (10A)
Left Low Beams (10A)
Column 4 (Top to Bottom)
Switch Illumenation (5A)
Def Sw Illumenation (10A)
Stop Lamps (15A)
Radio (5A)
Radio Memory (5A)
Right Hand Power Locks (20A)
Gauges/ Warning Lamps (5A)
Radio Mute (5A)
Right Low Beam (10A)
Hope this helps.
Apr 19, 2009 | 2002 Ford Taurus
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
1995 chrysler lebaron
Here's what mine says- for a 95 Chysler LeBaron GTC Convertible. I didn't see anything about a fuel pump, but maybe it's connected to something else? I dunno. Good luck. Here's the info at least.
1 HTR-AC 30A, 2 POWER WINDOWS 30A C/B, 3 PWR SEAT, LKS, TOP 30 A C/B, 4-BLANK, 5 BACK-UP LAMPS 20A, 6 TURN SIGNAL 20A, 7 REAR WIPER 20A, 8 ILLUM LAMPS 5A, 9 INTERIOR LAMPS 10A, 11 CIGAR LIGHTER 20A, 12 RS AMO 20A, 13 INTERIOR LAMPS 10A. 14 BOD COMP MESS CTR 5A, 15 SPEED CONTROL 2A, 16 GAUGES AIRBAGS 5A, 17 STOP LAMPS 18 HEAD LAMP RT-LOW 10A, 19 HEATED MIRRORS 5A, 20 AIRBAGS 5A, 21 STOP LAMOS 20A, 22 HORN 20A, 23 RT-TAIL LAMP-EUR 5A, 24 LT-TAIL LAMP EUR 5A, 25 HEAD LAMP LT-HI 10A, 26 HEAD LAMP RT-HI 10A, 27 RADIO 104, 28 FRONT WIPER 20A
Mar 29, 2009 | 1995 Chrysler LeBaron
Lincoln LS 2001 3.0
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment
Fuse Panel Description
9 10A Right Front Low Beam
10 5A Left Front Turn, Left Front Repeater, Left
Front Sidemarker, Left Front Park Lamps
11 10A Left Front High Beam
12 — Not Used
13 5A Cluster
14 10A RCM, DATC
15 5A Not Used (Spare)
16 5A E/C Mirror, Heated Seat Controls, RSM
(Rain Sensor Module)
17 5A RCM, Alternator Warning Lamp
18 20A Radio, CIA
19 15A Tilt/Tele Motors
20 10A FEM, DATC, Cluster, Brake Shift Interlock,
REM
21 10A Power Folding Mirrors
22 10A DDM
23 10A Right Front High Beam
24 5A PATS
25 10A Left Front Low Beam
26 10A Wiper Relay, Windshield Washer
27 10A Radio, Cellphone
28 5A Security Horn
29 5A Trailer Tow Ignition Sense, VEMS, FEM
30 5A FEM
31 — Not Used
32 20A Cigar Lighter
33 10A Switch Backlighting
34 10A Not Used (Spare)
35 5A Stop Lamp Signal
Oct 23, 2008 | 2001 Lincoln LS
Brother DCP-585cw All-in-One Wireless Color Inkjet Printer Logo
200 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
