Hi, does the rbc amt 31e (sx a1ee) come with a remote control? I am having trouble reversing the flow of air, please can someone help?
So it's winter and the heater is on. There are 4 units in the appartment, they work in sinc, apparently set up from the remote control to work as one system, programmed to come on and go off when you set the timer. We just moved in. The heater is pushing the hot air into the roof and nor heating the full room, shoulder hight there is no heat from the heater at all. One duct points to the roof and one down to the room.The Mode wont allow me to change one unit, the manual states that it has to be unselected from the group of heaters/aircon system to change a setting individually. The manual refers to 3 models, it is unclear if this pirticular model has a reversable air setting. I hope this helps, please assist it is freezing and the girlfriend is kranky over it.. Thank you. Henk
22yooper
  • 828 Answers
SOURCE: GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Posted on Apr 30, 2008
  • 104 Answers
SOURCE: my appartment does not have
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Posted on Oct 04, 2008
  • 6 Answers
SOURCE: no heat
No Blower in Floor Mode
A customer arrives with a 1983 to 1995 Full Size Ford, Lincoln, or Mercury
automobile with automatic temperature control. If the complaint is no blower operation when
the floor mode is selected, the vehicle may have a problem with the thermal blower lockout
switch also referred to as the CELO (cold engine lock out switch).
The thermal blower lock out switch is located in the heater core intake hose. The two
wire switch has a thermal element with a small set of contacts, the contacts are open when the
coolant is below 120°F and closed when the coolant is above 120°F. The thermal blower lock
out switch also contains a vacuum switch, which applies vacuum to the outside/recirculate
valve when the system is in the floor position. When the engine coolant is below 120 degrees
and the selector is set to floor position, the thermal blower lock out prevents blower from
turning on and closes off the outside air during engine warm-up. When the coolant
temperature is above 120 degrees, and the selector is set to the floor position, the thermal
blower lock out switch allows the blower to operate and opens the outside air door.
In order to diagnose this problem, test the thermal blower lockout switch with the
engine at normal operating temperature (above 120°F). Unplug the wire harness connector
from the thermal blower lockout switch. Using a 15-amp fused wire, jumper the harness
terminals to test the switch. If the blower comes on, the thermal blower lock out switch is
faulty. If the blower doesn’t come on, look for an open between the control head selector and
thermal blower lock out switch.
In some cases the blower may continually run even when the engine temperature is
below 120 degrees. Unplug the thermal blower lock out switch and if the blower motor turns
off, the thermal blower lock out switch is faulty. If the motor continues to run, look for a
short to power between the control head selector and thermal blower lock out switch
Posted on Feb 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Room Heat/Cool unit will not heat with heat pump
If it was me I would cnage the sensor first. Simply because it is way cheaper than the control board and these sensors are fickle as hell to begin with.
Posted on May 14, 2009
  • 333 Answers
SOURCE: 2005 highlander heater problem
I'm glad I could help. I'm reposting the solution below in case anyone needs it in the future. Please be sure to rate it for me!
Pull the temperature knob off and verify the thin 12mm nut is installed and tight behind it. I have seen several of these loosen up allowing the knob to turn but intermittently have no effect on temperature.
Posted on Sep 11, 2009
Rbc online banking sign in
Hi Evangeline,
Since you have issue accessing your online banking with RBC, why don't you try to talk to them to be able to assist you on how to resolve your issue. Here are ways on how to contact them:
If you are experiencing problems with RBC Royal Bank NetBank website please contact us at:
Apr 27, 2014 | Finance
Aprilia sx 50 2007 coolant light stays on, coolant level checked and is ok.
Hi Paulfinns you may have a faulty temperature sensor or grounded indicator bulb other the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2007 Aprilia Sx 50
Sep 14, 2011 | Aprilia JL 250A VGunn Motorcycles
Hi there i'm in world of trouble i've been working on my Nissan Armada 05 and i have got 4 error codes they are P1122 ETC FUNCTION CIRC, P0102 MAF SEN/CIRCUIT, P1031 A/F SEN1 HTR (B1), P1051 A/F...
CODE P1122 ELECTRONIC THROTTLE CONTROL ACTUATOR. CODE PO102 - MASS AIR FLOW SENSOR VOLUME AIR FLOW VAF SENSOR LOW INPUT. CODE P1031 - HEATED OXYGEN SENSOR HO2S 1 HEATER CIRCUIT MALFUNCTION. CODE P1051 -
May 20, 2011 | 2006 Nissan Armada
Ich habe einen Pioneer SX - 205RDS. Um eine Universalbedienung zu programmieren, brauche ich die Gerätecode-Nummer. Oder stimmt es, wie ich gelesen habe, das der Sx - 205RDS nicht...
You need to use a universal remote control capable of handling audio devices such as receivers. Even at that, you may have to resort to trial and error to find a remote control that works. All universal remote controls do not contain all possible codes.
Dec 22, 2017 | Pioneer SX-205 Receiver
I need to program my pionner sx-315 reciever in my directv remote control
I can help you with your Pioneer Receiver & DirecTV remote control.
This is a list of all the Pioneer Receiver control codes for DIrecTV remote controls:
31023, 30150, 30244, 30289,
30531, 30630, 30801, 31123,
31343, 31384, & 31935.
There are so many codes to try for Pioneer Receiver and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
May 25, 2010 | Pioneer SX-315
Large viewfinder only works when reversed &
dear ... there is an option in the menu .....
of hvr A1 TO KEEP THE VIEW finder.... ON..
write nw
ur camcorder is in auto mode ,wht happen in auto mode is ,view finder gets ON only when u turn the LCD pannel ...
so need nt worry change ur MENU option OF view finder from AUTO to ON,......
Jul 13, 2009 | Sony HVR-A1E HDV Digital Camcorder
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
