Question about Roomba Robotic Floor Bagless Vacuum
The left wheel just stops working. - Roomba Robotic Floor Bagless Vacuum
    New Friend:
You should take it back to the store
Posted on Nov 27, 2012
Our Roomba makes little gouges in the woodwork about 11" - 12" apart, what causes this?
Is it literally ripping through the varnish on the floor and tearing into the wood? Two gouges 11-12" apart sounds like the space for the wheels. I would look to see if there is anything wrong or missing from the wheels. Aren't the wheels rubber though? Also check the white/black ball wheel at the front. The axle for this can get clogged up with hair and it will stop turning. Then you're just dragging or pushing a locked wheel. I can see this might scrap the floor. Insert a small standard screw driver in the gap at the right or left and this ball wheel can be pried out. Then remove all the hair wrapped around and into the axle. Pop back into place when done.
Jun 29, 2014 | iRobot Roomba 560 Robotic Vacuum
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
Roomba 560: it only spins in one place, then stops & doesn't dock either.
If there's no message its probably a sensor malfunctioning. It might be a cliff sensor, the bump switch, or wheel-drop (left, right, or caster). Try cleaning the sensors and vacuuming things out as a first step.
Nov 22, 2009 | iRobot Roomba 560 Robotic Vacuum
It only spins in one place then stops
As said, if it beeps 9 times after stopping, than this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
Have fun
Avi
Roomba circles
Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
Have fun
Avi
Sep 12, 2009 | iRobot Roomba 560 Robotic Vacuum
My Roomba 560 just spins in circles and then stops and beeps 9
Perhaps its a wheel drop sensor instead of a cliff sensor. Clean the caster, caster axle, caster motion sensor, remove and vacuum or blow the dirt from the left and right wheel assemblies.
Aug 22, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba can't make a turn and stops working
make sure the wheels are not clogged with something like hair or carpet strands if that don't work it sounds like your right turn sensor might be bad.call the roomba people or go to roomba.com and look for your model and find troubleshooting
Apr 28, 2009 | iRobot Roomba 410 Robotic Vacuum
Front wheel problem
I would send it to protechrobotics. they will test all your components and let you know what needs to be done. if the repair is more than it's worth--they will help you out too.
http://www.protechrobotics.com/
Apr 07, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba circles and only goes backwards.
try cleaning the cliff sensors under bumper
Dec 13, 2008 | iRobot 5800 Scooba Vacuum
Leaking from left wheel when applying trigger onmodel 7901
Sounds like a problem with the left spray nozzle, may be out of place. Either that or a line is loose and leaking. Either way you will have to pull the top housing off to check it over.
Feb 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Roomba Robotic Floor Bagless Vacuum Logo
54 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
