Li 1705 not booting up, black screen & WiFi light always on
ginko
  • 19396 Answers
SOURCE: please help me what site can i download free for
To download the driver you need to follow instructions on website below.
Select your model and proceed to driver download:
Downloads - Support - Fujitsu Siemens Computers
Posted on Mar 04, 2009
  • 7993 Answers
SOURCE: White screen problems with my fujitsu siemens
Just a hunch. If external monitor is connected to computer when computer is turned on, video output is diverted to the external monitor. Turn computer on, without external monitor, then extend your desktop to an auxiliary video screen (monitor, TV , or projector.) Or you can configure your computer to use the internal LCD and the monitor. Check the graphics properties of the laptop.
Hope it helps.
Posted on Oct 04, 2009
  • 11800 Answers
SOURCE: i own an fujitsu amilo li 1705 and am tring to
Start, Control Panel, Display, Settings, in there you will see two monitor icons: the one with 1 it's the screen of your laptop, the one with 2 is the tv - click on it, in  Screen resolution select exactly the resolution of your tv, tick the Extend option, click Apply, click OK.
Posted on Dec 04, 2009
emallari27
  • 86 Answers
SOURCE: i cant download FS Amilo Li 1705 - Windows XP
Try to install Windows Vista instead because if you will be using XP there will be limited drivers under this link : http://ts.fujitsu.com/support/downloads.html but if you Install Windows Vista you might have all the drivers compatible with it . You might also try to purchase a recovery cd for xp thru Fujitsu Technology Solutions: +44 (1344) 475125
Business hours: Monday - Friday 9:00 - 17:00 GMT or locate you respective location thru this link
http://ts.fujitsu.com/support/servicedesk.html
- ERNZ
Posted on Feb 03, 2010
  • 1833 Answers
SOURCE: How do I remove the
Here is how you can remove the keyboard.
1. Power down and remove the Battery, this reveals 3 small cross-head screws.
2. Remove the 3 screws from the battery compartment.
3. Open the laptop and tilt the screen fully back i.e 180 degrees open.
4. Now you gently pries the cover off where the speaker grille and power switch is located.
5. The keyboard can now be slide forwards and tilted back on itself revealing the ribbon strip.
6. Where the ribbon connector is, gently slide the grey connector strip to the right, this releases the ribbon cable allowing the keyboard to be removed.
7. Refitting is the reverse of removal.
Posted on Dec 04, 2010
Hello I have laptop Fujitsu-Siemens Amilo Li 1705 It's no display on screen With 5 beeps 1-3-1 I am replace ram but no worked
If you remove the hdd, ram and dvd drive. Power up and then shut down. Place one ram chip in the slot, (ensure correct type and value). Is the error still there? If it is possible GPU issue.
Jan 05, 2016 | Computers & Internet
Powering up but black screen
backlight on screen doesnt work
Apr 05, 2012 | ASUS Computers & Internet
I need new biss key for ptv k feed
جناب پی ٹی وی ھوم کا نیا کوڈ چاھئے بہت ضروری ھے یہاں ھمارے گاوں میں کیبل ٹی وی کا پروگرام نہیں ھے ورلڈ کپ میچوں کو دیکھنا ھے اگر نیو کوڈ دیا جاییں تو بہت مہربانی ھوگی۔
zahir_star333@yahoo.com
mobile .03459518896
thanks**********
Mar 11, 2011 | Computers & Internet
My problem is online error
check the cable between printer and computer may be the cable is corrupted
May 30, 2010 | Samsung ML 1610 Laser Printer
I own an fujitsu amilo li 1705 and am tring to view on my tv (samsung plasma) no display on the tv ... have it connected properly and tv recognises that laptop connected but there is no display .. just a...
Dec 04, 2009 | Computers & Internet
Fujitsu siemens amilo li 1705 LAPTOP FAN TURNS LED LIGHTS BUT HAVE NO DISPLAY
fan keeps turning or turns off right away?
have u tried taking memory out and putting back in?
if so could be lcd or processor
Nov 25, 2009 | Dishwashers
White screen problems with my fujitsu siemens amilo li 1705 from boot. External monitor activity suggests system is good.so assume it is not the motherboard. How can I test the LCD cable wire or the screen...
Hope it helps.
Oct 04, 2009 | Fujitsu Siemens Computers & Internet
Memory upgrade for laptop - not sure what to unscrew
Most laptops are this way, but yours may be a special case.
Most have two ports one is underneath a removable panel on the bottom of the computer, and the other is under neath the keyboard. To remove, look to see if you can remove the area between the keyboard and screen, if not find a screw or screws on the bottom of the keyboard labeled "k", once those are off the keyboard is loose and is just lifted off.
Always remember to not prey to hard,if it is going to come off it will come off without struggle, and have your battery and power disconnected first, and the computer is off...
Jun 17, 2009 | Fujitsu Siemens Computers & Internet
Can i upgrade my video card in the amilo li 1705 laptop and also the battery life time is very very short
Yes you can buy it to nearest computer shop and bring your laptop, I believe they will recommend you the best they have that fit your amilo li laptop! You must replace the battery pack with NEW one, I once try to change the cell, but it absolutely no good. When you charge the battery, charge it when your Laptop turn-off. Better charging time is not more than 4Hours. And if you intend to use your laptop more than the battery life, or when you want to use your laptop with AC power, please remove the battery pack. Always charge the battery pack when your laptop turn-off! GoodLuck!
Jun 13, 2009 | Computers & Internet
Warp in world 3 ghost house
It's one of the hardest things to do in the whole game in my opinion... there's not really any trick to it, you just need to keep practicing. I must have tried about 50 times before I made it! ;) there's always somewhere you can shave a fraction of a second off. Sorry I can't help more than this.
Feb 25, 2009 | Nintendo New Super Mario Bros. for DS
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
