Question about iPhone Apps
How do I put a caller tune on iPhone - iPhone Apps
How can I retrieve my caller tunes from iCloud after a restore on a(n) iPhone 6 plus?
I have read of others having same problem of missing tones after restore or upgrade. Fwiw - I always save backups of everything on my iphone to my PC using iTunes and only use iCloud as my secondary backup. Using iTunes allows selection of each category including "tones". Even though the tones were restored, I found that each contact was reset back to default. I had to go back to each contact, select "edit" and then select "ringtone" which brought up the listing of available tones and all my custom tones were at the top of the list.
if you purchased ringtones or downloaded free ring tones from the iTunes Store and they are missing, you should be able to go to the iTunes Store on your iPhone, select "more" then select "purchases" and re-download them, they may only be listed under the music category. Although I also have heard some people are missing ring tones from their purchases. In this case, you will need to email or call apple customer service.
if all this fails, your can use iTunes or any other music editor to make your own ring tones. Basically you save a copy of the song in m4a format, edit the start and stop times to be 30 sec max play time and save the clip as an .m4r file. You can google the procedure, it's fairly easy. In iTunes, save the clip with a new title then go to the actual file location on the hard drive and simply change the file extension to m4r, then add the file to iTunes and it will show up under "tones", repeat as desired then you can sync the tones.
without iTunes, you need to use an app to make ring tones on your iPhone - Apple has not yet provided this functionality.
Mar 05, 2016 | Apple - iPhone 6 Plus 16GB
Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
Jul 10, 2007 | Motorola Mobility E815
Cannot upload iphone pics to acer
Can your computer read the file type from iPhones?
Apr 18, 2014 | Acer Aspire One PC Notebook
Iphone 5 can't hear callers but the hear me, speaker phone works
I have written up a useful guide on how to fix the iphone 6 can't hear caller problem iPhone 6 Can Hear Caller Fix
Nov 02, 2012 | Lands Phones
Want to set caller tune in lyca sim
i want to sset caller tune in my lyca sim plz tell me how can i set caller tune
Jan 19, 2012 | Cell Phones
Caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
Jun 14, 2011 | Apple iPhone (16 GB) Smartphone
My iphone has my last name wrong on caller ID
Your iPhone uses the name that is listed in your address book for called ID. On your iPhone, go to Contacts, click on the name of the contact you wish to edit, hit Edit in the upper right-hand corner, and then change the last name accordingly. Once you are done, hit Done on the upper right-hand corner again, and now the correct name will show on caller ID.
Jan 28, 2011 | Apple iPhone 3G
How to make a caller tune on samsung t229
To set an caller tune you have to contact your Service provider.As the only they have authorization to set an caller tune. Just call to your service provider and they will guide you to select your caller tune which ever you want.
If you have any more queries then please get back to me here. All The Best Thank you for using FixYa.
With Regards:- Subhankar Ghosh
Jan 09, 2011 | Samsung SGH-t229 Cellular Phone
How to delete caller ringtone
I just confused with your quwstion, i am not sure that is caller tune or ringtone . To delete caller tune please call to your network provider customer care, they will deactivate it. For ringtone go to profile and select ringtone select the option as off... Hope you will succeed/.....
Dec 28, 2009 | Nokia 6233 Cellular Phone
Message Bank
You may have activated a "Caller tune" or "Ring back tone" service. Check with your service provider to deactivate the tune.
Apr 05, 2007 | Motorola Mobility RAZR V3
iPhone Apps Logo
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
