Question about Refrigerators
FH-26 yams minni fridge
Need 12volt 4 amps power cord
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: need 12volt power cord for
Hi, you should be able to find a 12 volt power cord at Radio shack or any electronics replacement parts store around you....
Posted on Feb 05, 2011
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    With 26 minutes remaining FH appears where the time is displayed and the wash stops. What does FH mean
    Hello & Welcome to FixYa
    FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
    Kevin
    May 03, 2011 | Washing Machines
    My fridge will only work on 220 volts but not on 12v or gas anymore. the fridge worked perfectly then the gas stopped working one day, i discovered that the gas pipped was blocked, after unblocking it the...
    Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
    Apr 08, 2011 | Refrigerators
    The fridge stopped working. what to do. its three years old
    It could be due to following reasons 1 There is no power supply. Check the power cord and the plugs. Ensure that there is bend/breakage in the power cord. Ensure that the plugs are connected properly with the cord. If the lamp inside the fridge is lighting that means the power supply is OK. 2 The compressor has stopped functioning or burnt due to overload. 3 The gas has leaked out. You must have noticed less cooling over the months. 4 Check the thermostat switch.
    For 2 & 3 you will have to call a technician. I hope you have been carrying out the servicing once a year.
    Nov 03, 2010 | Whirlpool Refrigerators
    Amp is getting power but its not playing
    Checking wires doesn"t help unless you are checking them with a multi-meter. Amp needs 4 things to turn on. 1) 12volt power from battery, 2) 12 volt power from radio (remote turn on), 3) ground (solid ground to the chassis or the car free from paint or rust), 4) fuses on side of amp need to be good. If any of these 4 things don't measure up then fix them so they do. If all 4 are verified with the meter and still no lights then you might have a dead amp. If the lights are on but no sound, then there are many other things that needs to be checked.
    Feb 27, 2010 | Car Audio & Video
    Bought a refurbished x2gen monitor, sent the wrong power adapter, not sure what one I need. The sticker on the back of the monitor says 12volt 4.0 amp but no hertz do you have any idea
    You need to check on the monitor itself.Most of them will normally mention their ratings etc,,now 12v , 4 amps means 12*4 = 48 watts.So you can use a different adapter as long as it matches the power and voltage and it has the applicable connection.
    Dec 08, 2009 | X2Gen Computers & Internet
    POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
    bjw122266 Have you tried holding the power button down for about 10 seconds or so?
    Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
    Refrigerators Logo
    71 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
