My son's Nintendo DS Lite reads a message when we insert any GameBoy Advance Game into the unit in the correct lower slot. The DS games work perfectly normal when we try them. It reads Saved Data corupted when we turn the unit on with the Game Boy Advance game in the slot. This happens with any game we try. Does any one know how to fix this or is the Game Boy Advance slot no good anymore.
Is it definitely "any" game? Reason is that a lot of games are now suffering from flat batteries, the symptom of which is what you're saying, corrupt save data.
The only solution is to change the battery if thats the case.
If you are inserting a DS card, be sure there are no foreign articles inside the slot. Blow into the DS card slot to clear any debris. Also be sure you are inserting the card all the way in until it clicks. I've also found that if you're powering on a game, and you bump, grasp or touch the ds card as the DS is powering on, that can cause it to not read games.
Check the actual DS card itself and carefully look at the exposed contacts on the circuit board. Be sure none of them are scratched, damaged or otherwise. A scratch can damage a contact, thus preventing proper data read.
If anything was spilled onto the DS card, be sure it is thoroughly cleaned with a damp cloth (no cleeaning chemicals!) If you immerse the DS card, or pour liquids on it, that may damage it as well.
Same points hold true for inserting a Gameboy Advance game (if you have a DS or a DS Lite. The DSi and DSiXL do not have Gameboy Advance slots.
If you turn on the DS and nothing happens, try a different DS Card. If it only happens with that one particular game (or games) your DS cards are damaged or need cleaning. If all your games are not playing, there is a problem with your DS. Try your games in a friend's DS just to make sure. You'll probably have to send the unit to Nintendo for repair, or take it to an authorized repair center.
Last time I had this I had to change the motherboard, tried for hours to find the fault. motherboards are about £50 if you have to resort to it. Make sure you are buying an original nintendo and not a copy
i had the same problem once but just with one game.has the micro chip ben touched
a lot if not you probly need a new game sensor instaled . ya know some dont work .......
i mean the ds sorry or you need a new ds relllllly sorrrrrrrrrrrrrrryyyyyyyyyyyyyy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
had this problem, i looked into where the game goes and one of the little metal teeth was bent, so i took a long toothpick and gently pushed it back over now it works fine. Be careful that you dont break it off though.
Shut the hell up I think you're the idiot because i'm familar with the ds and ds lite and i am 100% sure you can use game advance games. My sollution is game boy advance games do use L and R buttons but maybe the specific game does not.
Hi. the same thing sometimes happens to me. but i find if i remove the cartridge and blow into it and the slot on the DS then insert the cartridge firmly back into the slot it will work. it seems that even the smallest speck of dust will affect it.
