Question about Intel D946GZIS Motherboard
Intel 946 GZIS original motherboard Lan Problem
I have intel 946 GZIS original motherboard.It has integrated lan.Suddenly it is sowing some problem.this lan is working fine for 1st 10-12 minutes.then my broadband connection is not working.I checked that my DSL router is working fine.Can anyone please help me out?
  • 2 more comments
  • nilrock2010
    nilrock2010 Feb 14, 2012
    However usb connection of the same router is working fine
  • nilrock2010
    nilrock2010 Feb 17, 2012
    I have checked all your suggestions and all the above mentioned things are working fine..and my problem is not yet resolved.
  • Brian Sullivan
    Brian Sullivan Feb 17, 2012
    click start type cmd press enter you will be in DOS mode
    type in ipconfig press enter
    you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
  • Brian Sullivan
    so you have an internet connection for a short time ?
    would this be right ?
  • Intel Master
  • 27,725 Answers
Check the ethernet or usb lead connections make sure they are good with secure connections and you might have to reinstall the drivers
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
hope this helps
Posted on Feb 15, 2012
  • nilrock2010
preachw996
  • 1179 Answers
SOURCE: i have intel D946 GZIS
The driver for the LAN will be on the Intel website. Click on the support section and find your board. All drivers will be available for download. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 27, 2008
Chinthakaj
  • 416 Answers
SOURCE: I cant install the LAN driver for Intel 845 motherboard
Here is the link for the download. it gives a list of the supporting motherboard models as well.This drive only supports OS:Windows* 2000, Windows* XP Home Edition, Windows* XP Professional
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=889&DwnldID=5406&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
hope it works. cheers
Posted on Mar 20, 2009
  • 147 Answers
SOURCE: lan driver
go to the intel website http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2766&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DRV. here are all drivers for your mainboard, for the win xp professional. if you want another operating system just type in search system that you want
Posted on Apr 05, 2009
buffalonyman
  • 1865 Answers
SOURCE: want lan driver for intel 915 motherboard onbord
Go here and select correct operating system: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2157&lang=eng
Posted on Apr 25, 2009
  • 400 Answers
SOURCE: i am not abel to install intel d845gvsr lan drivers for 2000 prof
The drivers are here ,install the chipset ,lan etc:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+2000&lang=eng&strOSs=19&submit=Go%21
The USB you will have to get from windows update
Posted on May 19, 2009
Motherboard specification
Intel 865GV Chipset Pentium 4 Main board,
Supports Prescott CPU
FSB800, DDR 400, SATA 150 Specifications
arrow_bullet.gif CPU
  • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
  • Supports Intel Hyper-Threading Technology
arrow_bullet.gif Chipset
  • Intel 865GV/ ICH5
  • Integrated Intel Extreme Graphics 2
  • Supports Advanced Configuration and Power Management Interface (ACPI)
arrow_bullet.gif Memory
  • Two 184-pin DIMM sockets
  • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
arrow_bullet.gif Graphics
arrow_bullet.gif SATA 150
  • 2 channel Serial ATA 150MB/s data transfer rate
arrow_bullet.gif Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports optical S/PDIF Output
arrow_bullet.gif System BIOS
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
arrow_bullet.gif LAN
  • On board 10/100Mb LAN
arrow_bullet.gif Internal I/O Connectors
  • 3 x PCI slots
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 2 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
  • 1 x CD-IN, 1 x AUX-IN
  • 1 x FP-Audio header
arrow_bullet.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Parallel Port, 1 x Serial port
  • 1 x VGA Port
  • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
  • 4 x USB 2.0, 1 x RJ-45 LAN Connector
arrow_bullet.gif Miscellaneous
  • Micro ATX form factor (244mm*234mm)
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    hope this helps
Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
One of Intel DP55kg Motherboard desktop shows 100 mbps Lan connection when the other desktop shows 1gbps. why?
It depends upon the make and model of the LAN card. The one in the Intel may be a 10/100Mbps LAN card and the other one a 1Gbps LAN card.
You cannot make a 10/100Mbps LAN card run any faster than it was designed for.
May 11, 2011 | Intel DP55WG Motherboard
Audio drivers
Checkout the following link for driver download
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+946+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D946GZIS
Hope this helps!
CreativeTECH
Nov 10, 2010 | Intel D946GZIS Motherboard
Awrdacpi multimedia audio controller
The "audio-controller" is integrated into the Intel motherboard.
So, access 'www.intel.com' and follow the "Support" link to find & download & install the "audio" driver for your specific model of motherboard.
Nov 05, 2009 | Intel D915GAG Socket 775 Motherboard -...
Acer S88M motherboard where can I find a real Manual showing pinning headers or shunts layout
Hi There, Here is the specs of the board ,hope this helps you
Model: Acer S88M
Standard microATX form factor
Socket 478 Intel Celeron or Pentium 4 cpu up to 3.06GHz
400, 533 FSB
Intel 845GL / ICH4 chipset
PC2100, DDR-SDRAM, 2 DIMM slots, Maximum 2GB
3 x PCI slots
Integrated Intel® 845GL on-die VGA with DVMT 2.0 technology, Maximum VGA shared memory reaches 64MB 3D VGA adapter
Integrated audio Controller: Intel ICH4 AC97 Codec
Integrated 10/100 ethernet adapter Wired LAN: Embedded Intel® 82562 10/100 Mbps LAN
Wake-On-Lan
Alert-On-Lan
PXE 2.0
2 x ATA100 IDE, 1 x FDD controller
1 PS2 Keyboard, 1 PS2 Mouse port,
Audio line in, line out, headphone out, and 2 Microphone in,
4 USB Vers. 2.0, 1 Parallel, 1 Serial
May 28, 2009 | Computers & Internet
Where and what (sim card only, wireless card+sim card ??) to put into an hp nc6000 laptop to have benefit of what is yet inside (or supposed to be inside like the antennas ) and access to internet ,...
A wireless card should be already be in that system. There is no SIM card. According to HP's specifications, your laptop should have one of the following wireless devices integrated into the laptop:
The HP nc6000 notebook supports a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option and can be combined with any one of the supported wireless LAN options. All integrated wireless LAN options Wi-Fi certified
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) support
802.1x standards support including EAP-TLS, Protected
EAP (PEAP) and Cisco-EAP (LEAP)
Dual antennas integrated in the display enclosure HP W500 802.11a/b/g Integrated support for 802.11a, b and g
Up to 54mbps throughput performance
Advanced Encryption Standard (AES) support Intel PRO/Wireless 2100 802.11b wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b
Up to 11mbps throughput performance Intel PRO/Wireless 2200 802.11 b/g wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b and g
Up to 11mbps throughput performance Integrated Bluetooth Designed to the Bluetooth v1.1 specification
The full information is here:
http://h18000.www1.hp.com/products/quickspecs/11794_na/11794_na.HTML
If everything is working properly, all you have to do is find your local Starbucks or other WiFi hotspot and connect.
Mar 09, 2009 | HP Compaq nc6000 Notebook
Where i can get sis315 integrated
hi just go to this url. http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1672&lang=eng and select of operating system that's all
Feb 12, 2009 | Intel D915GAG Socket 775 Motherboard -...
I have intel D946 GZIS mother board ,i have reinstalled the o.s, iam not able to find the lan drivers in intel website,and i have lost the motherboard c.d,
Dec 27, 2008 | Intel D946GZIS Motherboard
Intel D946GZIS Motherboard Logo
110 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
