Question about Elinchrom Flashtube for the EL250 EL500 Style 300 and Style 600 Monolights
Elinchrom Style 100BX error code E.6?
Elinchrom Style 100BX Problem 1 minute after switching on power (from cold), I get error code E.6 and the flash won't work. Turning the unit off and on again solves the problem for another 60 seconds. If I use the flash within 60 seconds, it works fine - until 60 seconds elapse without it being fired, then I get the error code and have to switch off/on again. Just prior to this problem I changed the flash tube which, as far as I can tell, went without a hitch. The unit is COLD - it never gets a chance to warm up, so it shouldn't be heat-related. Any help would be greatly appreciated, thanks.
Same problem here. Answers?
Posted on May 08, 2016
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Elinchrom fx 200 ri. How can I reset?
To reset your strobe, follow these steps:
1. Switch the unit "off"
2. While still off, with one hand, press and hold both the flash-power up & flash-power down buttons (#10 in the picture).
3. Keep holding the buttons pressed and turn the unit back on with your other hand.
4. The Digital LED will flash in fast mode for a few seconds. Release the buttons. The unit is now reset.
Support for Elinchrom products is available at the link, below, including downloadable manuals.
ELINCHROM
Oct 16, 2013 | Elinchrom Cameras
F2 code is on, wont complete the spin cycle, try to reset with cancel and goes to 12 minutes, what is wrong with it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Keep in mind it is cold winter and the drains could be frozen or slow in the western hemisphere.
More here
Dec 20, 2010 | Kenmore Washing Machines
Elinchrom flash unit giving very weak flash
If battery is over three years old, time for replacement.
a.l9609@gmail.com
Feb 02, 2010 | Elinchrom 20499 Ring Light Flash
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Elinchrom Monobloc 250 capacitor replacements
Because of the high voltage and amperage, I would not suggest you replace it without intimate knowledge of the unit itself. Return it to Bogenimaging.us service department and they will fix it.
Nov 27, 2009 | Cameras
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Elinchrom Flashtube for the EL250 EL500 Style 300 and Style 600 Monolights Logo
405 people viewed this question
Top Elinchrom Cameras Experts
Doberman
Vivian
Vivian
Level 1 Expert
Are you an Elinchrom Camera Expert? Answer questions, earn points and help others
