Question about Samsung ST45 Digital Camera
If i take a still shot it looks like the picture is over exposed, any ideas
    Problem Solver:
  • 12 Answers
Could restore to fabric settings!, you could trie checking lighting options depend on if your outside or inside..change values and see..
Posted on Feb 11, 2012
  • 3 Answers
Take out the memory card on your camera and do a reset on the settings,
this will erase all stored settings on your camera. If you are still having issue the camera needs to be set up for repair
I hope this could help you.
Posted on Feb 23, 2012
Lines in pictures
There are two common faults for this problem. 1 is shutter failure and the other is sensor failure. To determine which is simple. For shutter failure put the camera in full optical zoom. Turn off the flash and look through the lens and take a picture. You should see the shutter completely cover the lens inside. Any gaps will result in over exposed pictures or horizontal lines. the other is video mode. if the problem is apparent in video mode too then sensor failure is the likely problem.
Aug 24, 2012 | Sony Cyber-shot DSCS2100 Digital Camera
I have a D70 with 26,000 shutter releases. Just recently it stopped composing pictures. In other words, I can take a pic just fine, but the playback is black, it saves to the CF card, and if I look at on...
Remove the lens and fire off a few shots while looking inside. Check to see if the mirror flips up out of the way and that the shutter opens exposing the sensor.
Oct 09, 2011 | Nikon D70s Digital Camera
Whenever I'll take a picture specially in outdoor enviroment, when I download the to my computer it seems the picture has so much light appearance. It's seems picture is over expose for the light...
It may be that you have inadvertently set your camera to shoot 'bracketing up' - ie over exposing for every shot. You need to look at the exposure ruler which looks something like this: l---l---l---l---l The centre bar is the correct exposure. But there is a little block that sits where you have got your +/- setting at. +/- is the sign for BRACKETING - where you tell the camera to over expose (+) or under expose (-). With Canon if the little block is to the right of the centre bar then you are telling the camera to over expose. Where is your little block? If it is to the right of the centre press your +/- button and turn the dial to the centre bar. NOTE: As digital cameras are WEAK in capturing highlights it is often better to shoot slightly under exposed - with your block set on the first or second horizontal line to the left of the centre bar. This means you are shooting 1/3 or 2/3 of an f/stop under exposed. Hope this helps.
Dec 31, 2010 | Canon PowerShot A470 Digital Camera
Pictures look blurry
try changing the setting it is in... or mabey it is in macro which is for close up shots.
Nov 11, 2009 | Canon PowerShot SD600 Digital Camera
Cannot get rid of graining and white out
have a look at my tips page on my profile for white lines or over exposed pictures under "THE ONLY WAY I KNOW HOW" It should give you an idea as to the fault
Sep 20, 2009 | Fuji FinePix E550 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Optimus Premier DS-5080 Picture over exposure
i need a charger for premier ds-5080 camera any ideas please
Jun 20, 2008 | Optimus DS-5080 Digital Camera
Geeting White Picture from Canon Shot shot s1 power shot camera
The pictures are over exposed. did you put the iso on max? Is the exposure correction set to the max?
Feb 04, 2008 | Canon Cameras
Olympus C2000 picture quality
There are so many variables that effect your exposure. Batteries, ISO rating, shutter, aperture, etc. Remember your pictures are digital, and you should have a good graphics program to make adjustments (e.g. Paint Shop Pro, Photoshop, Photo Deluxe, etc.). I suspect your pictures are under- exposed due to weak batteries from using the flash so much. The only batteries suitable are NiMHs. NiCad or Alkalines will not cut it.
Sep 11, 2005 | Olympus Camedia C-2000 Zoom Digital Camera
Samsung ST45 Digital Camera Logo
301 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
