Question about Cameras
Elinchrom Style 100BX flash head gives error code E.6. 1 minute after switching on power (from cold), I get error code E.6 and the flash won't work. Turning the unit off and on again solves the problem for another 60 seconds. If I use the flash within 60 seconds, it works fine - until 60 seconds elapse without it being fired, then get the error code and have to switch off/on again. Just prior to this problem I changed the flash tube which, as far as I can tell, went without a hitch. The unit is COLD - it never gets a chance to warm up, so it shouldn't be heat-related. Any help would be greatly appreciated, thanks.
SOURCE: heating control for a 2004 ford explorer
I have a 2004 ford explorer the heat is not working.
Posted on Nov 02, 2008
  • 2039 Answers
SOURCE: Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Posted on Nov 09, 2008
davespcr
  • 115 Answers
SOURCE: Overheating and Heat doesn't work
Sounds to me like air trapped somewhere in the coolant's path. You said there's a warm spot on top of the engine. This makes me think of possibly a cracked intake manifold or cylinder head. Did it overheat right before this started? I would have the coolant system 'back flushed' and if the problem is still there, I'd next do a compression test (with the radiator cap off).and check to see if there are air bubbles in the radiator while testing. Good luck, please let me know what you find.
Posted on Jan 18, 2009
cadman000
  • 607 Answers
SOURCE: problem with front air switching to heat when accelerating
Check for a vacuum leak. WHERE is the magic question.
Posted on Mar 27, 2009
heimlich
  • 1978 Answers
SOURCE: I have a 2002 Galant. Air works fine, but when I
There is an electric motor that turns heater core on and off. It's located under the dash to the left of the glove box. Some disassembly required. The part will cost about $120 to $180. part number is #MR958603. I saved money by purchasing it on line. It is a stocking part at most Mitsubishi dealers. Once you pull the glove box out and remove the bottom half of the dash all the way across, you should be able to gain access to the motor to replace it. Caution: if you do not put everything back in correctly and tie/tape it all back down carefully in the correct places you will have lots of under the dash noises when you are done.
Posted on Oct 20, 2010
Epson Stylus CX7800 All-in-One Printer ERROR CODE 0X9A
Hi
I would hazard a guess that the print head electrics have been flooded with ink causing this error, you could try giving the whole area a good splash and clean of alcohol then blow dry the heads with a hair drier set to cold for a few minutes.
Before carrying out any work on your printer make sure you unplug it from the wall first and then leave it for an hour before powering it back on again.
Good Luck Mark
Sep 13, 2014 | Office Equipment & Supplies
OBDII Codes 2006 Chevy 2500HD w/ 6.6L Duramax "Truck started losing power when warm, when cold for the first 10 miles or so the trunk runs great."
You need a dealer, there is a real problem going on here, way over the head of any home do it yourselfer. The main reason is the special tools required to interface with the control modules that are throwing these codes
Jun 29, 2017 | 2006 Chevrolet Silverado 2500HD 2WD
My fx 200ri shows E1 & didnt respond
plese read your owner manual for to fix the error codes. God bless you
If you have a more serious digital camera problem and the camera gives you an error message, check your user guide and this list of camera error guides to try to fix the problem. Good luck with your efforts to troubleshoot camera problems!
Another trick to try clearing the lens error message is to press the power button at the same time you press the shutter button. This is a long shot, but it does work on occasion
Nov 08, 2013 | Elinchrom Cameras
Elinchrom fx 200 ri. How can I reset?
To reset your strobe, follow these steps:
1. Switch the unit "off"
2. While still off, with one hand, press and hold both the flash-power up & flash-power down buttons (#10 in the picture).
3. Keep holding the buttons pressed and turn the unit back on with your other hand.
4. The Digital LED will flash in fast mode for a few seconds. Release the buttons. The unit is now reset.
Support for Elinchrom products is available at the link, below, including downloadable manuals.
ELINCHROM
Oct 16, 2013 | Elinchrom Cameras
Elinchrom flash unit giving very weak flash
If battery is over three years old, time for replacement.
a.l9609@gmail.com
Feb 02, 2010 | Elinchrom 20499 Ring Light Flash
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
