Question about Zanussi Dishwashers
Replace door spring zanussi dishwasher - Zanussi Dishwashers
  • 409 Answers
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
Posted on Sep 23, 2008
  • 10865 Answers
SOURCE: ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Posted on Jan 28, 2009
  • 1314 Answers
SOURCE: Dishwasher door spring
remove the lower kickplate open the door hook the spring on the hooked part of the door and then in one of the holes in the frame youll see
Posted on Feb 11, 2009
  • 258 Answers
SOURCE: F & P dishwasher 913T/87198 - ? how to replace door springs
I have done this on another make, but most front loading are very similar see pictures and solution here:
http://www.howtofixanything.co.uk/howto-260.html
Posted on Feb 25, 2009
rickead1
  • 1998 Answers
SOURCE: Broken door spring on Kitchenaid dishwasher
you have to pull the unit totally out so you can access both sides of the machine you can order the parts from either marcone or allbrands applaince they mail the parts directly to you when you have the unit out you will be able to see its an easy fix of just replacing springs and cord if im remebering correctly theres only two 1/4 screws to loosen one on each side you will be replacing the glide rollers also in the kit they send you with the cord are the glide rollers
Posted on May 01, 2010
Door springs
If the door won't stay shut the issue is with the door catch not the door springs, But if you want to know where the door springs are you need to remove the outer cabinet of the dishwasher and you will see them on the lower sides.
Mar 04, 2012 | Zanussi Dishwashers
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Zanussi DW 908 door mechanism is faulty. The counter balance has failed. How can this be resolved?
You need to remove both side panels to allow you to gain access to door counterbalance springs. Visually see what is broken or come off of allignment then rectify.
Sep 17, 2009 | Dishwashers
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Broken spring on Zanussi dw908 dishwasher door
hi. thanks for the question. remove the bottom kick plate. 4 screws at the bottom. 1 spring each side . replace both springs . thanks the appliance doc
Oct 06, 2008 | Washing Machines
Dishwasher
i have just purchased a Zanussi ZDT6255 intergral dishwasher but i have havn't any fitting instructions just the machine an 2 brackets. is there anywhere i can obtain the complete fitting instructions?
Jan 14, 2008 | Zanussi Dishwashers
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
204 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
