Question about DeVilbiss Air Tools & Compressors
Devilbiss gti pro air leakage
Air leakage in air cap
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Posted on Dec 30, 2009
Need to bleed fuel lines on 1490 case to start it what is cause
You've a fuel bleed back from injectors and pump because there's a leak somewhere that is not noticeable. This leak is letting air in while cranking it and there must be no air in the system. It may not be a large enough opening for fuel to come out to be noticed, but still just large enough for air to be sucked in. Put Light air pressure to the fuel tank with the cap on to make it show you the leak position. Soon as you see the leak, take the fuel cap off and shut down the air pressure. Fix the leakage problem, re-pressurize the tank to get fuel back up, then fire it up.
Aug 17, 2017 | Cars & Trucks
Air leaking from cap on Ozark air mattress
There should be an internal one-way inflation valve that prevents leakage. The valve may be failing to close completely.
Aug 24, 2016 | Ozark Trail Velour Top Airbed Kit Queen
This is a cap start 3HP 220 volt, air compressor what capacitor does it need
the best place to buy capacitors from is a electric motor rewind/repair shop
take all the details off the motor plate and the old capacitor and they will be able to advise of the correct capacitor to use and sell you one for it
Nov 29, 2015 | Dryers
2003 Honda Civic LX code 1457 HELP
Error Code: P1457 Description - Evaporative Emissions Control System Leakage.
Causes:
- Fuel is filled with the engine start.
- Missing Fuel cap
- Wrong fuel filler cap is used
- Fuel filler cap seal is leaky.
- VSV Valve connector near air filter box is detached or wire broken.
- VSV Valve vacuum pipe near air filter box is detached.
Jun 01, 2015 | 2003 Honda Civic
Leaking lid seal f&p dd 601
Can be caused by leakage of the exhaust valve. Either the exhaust valve is not operating (corrosion of the contacts) or there is wear on the rubber cap of the solenoid plunger that holds the air pressure in the lid seal. You can resurface the face of the cap by rubbing it on some 320 abrasive paper placed on a flat surface and keeping the plunger vertical as you move it back and forth. You will see the indentation in the cap from the tube end that it is suppose to seal. This is what needs to be removed. You can test for this condition by crimping the small length of tube that goes into the exhaust solenoid with a small clamp and starting a wash cycle. If you don't have any leaking during the first stage of the wash cycle then the exhaust valve leakage is the problem.
Jun 01, 2011 | Dishwashers
Were is the termosat loctated
In the housing at the end of the upper radiator hose.
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. If you get stuck, please get back to me. Below are specific instructions for your car.
  1. Drain the cooling system and tighten the drain plug.
  2. Disconnect radiator hose from thermostat cap (thermostat housing).
  3. Remove thermostat cap.
  4. Remove thermostat.
To install:
  1. When installing the thermostat, be sure to position it so that air bleed valve comes uppermost and into the recession of thermostat case.
  2. Install thermostat cap. When installing cap, align arrow marks on cap and case.
  3. Connect radiator hose to thermostat cap.
  4. Fill cooling system.
  5. After installation, check each part for leakage.
Oct 29, 2010 | 2000 Suzuki Esteem
2000 honda accord code pulled was P1456 Evap control system leakage how and where do i find this leakage. engine 2.3L
This may be as simple as your fuel cap not sealing correctly. You may want to throw on a new fuel cap and unhook the battery for 5 minutes to clear the code and try again. I have seen several types of cars throw these codes due to a bad fuel cap.
Hope this helps.
Aug 31, 2010 | 2000 Honda Accord
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a RCA tv wont turn on and makes a high squealing noise
Your TV is actually functioning but their is probably a leakage on high voltage supply.
Warning : The next procedure should be done by an expert.
1.Clean the anode cap mounted on the CRT.But before touching the cap be sure that the voltage stored in the CRT is discharge to avoid risk of electric shock.It is done by creating a path of conduction from anode cap to chassis ground.
2.After cleaning the anode cap and the CRT surface.Attached the anode cap to the CRT.Be sure after attaching the pins correctly push and vacuum the socket and the cap to seal leakage.
Jul 14, 2009 | Samsung TXN3271HF 32" TV
Air Tools & Compressors Logo
197 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
