SOURCE: Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole. If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD. Hope this helps!
SOURCE: my sanyo DVR-V100E combi dvd/vcr
sanyo dvr-100e
stays in waiting mode will not come on fully after a minuit will go off
SOURCE: I have a JVC VCR/DVD-recorder,
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
SOURCE: Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
