Question about Miele Washing Machines
No spinning miele w1614
No spinning
Miele vacuum
Check the end caps on the brush roller they might have collection of dirt build up also the unit nust be assembled correctly with no air leakage by the fan so the suction can spin the fan
thiis turbl is made by wessell for Miele the replacement is just as good under their brand for a lot less money
miele turbo nozzle carpet and bare floor brush
Jul 02, 2016 | Miele Vacuums
Out of balance when spin starts
Hi dear. Your machine needs new shock absorbers and drum tension springs replacement. I can advise to contact your local Miele center. Thanks.
Apr 01, 2016 | Miele Washing Machines
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
May 11, 2012 | Miele Vacuums
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
Spin light flashhes spin does not work
The Miele W864 model will flash a warning light and will refuse to spin when it considers its load to be unstable....What I mean is... if you put a blanket in it and the blanket is on one side of the drum, the computer decides that if the machine spins, the centre fugal force or whatever they call it, the weight of the thing inside, will make the machine move about dangerously and will therefore not spin... its a safety feature. My spelling is shocking... I will look at the manual. Which says the load is unstable... more or less... waterlogged garments, like blankets can do this.... I normally just fill it with towels, and wash twice or three times because I wont get a good wash when overloaded.xx
Nov 12, 2011 | Miele W864 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
