Question about Refrigerators
Taylor coolatta machine
Hopper not getting cold
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
How to recognize why 339 raylor is not giving good product viscosity
If the machine runs and runs and can't satisfy your viscosity setting there is a refrigeration problem. The longer the machine runs the more the product breaks down, so you're problems get worse as the day goes on. It's not uncommon for these machines to lose refrigerant. I would guess that is the issue here.
You will need a refrigeration repair person to put gauges on the machine.
Here is some information I put together about the logic board adjustments on your machine. I think you might find this helpful.
Taylor Softech Control Boards
May 28, 2017 | Taylor Ice Cream Makers
Wellspring yogurt machines
Did you find a solution ?
Feb 10, 2014 | Taylor Ice Cream Makers
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
I took apart a Taylor 430-12 Frozen Margarita machine and need help on trying to reassemble it...
Taylor 430, craziest issue. Liquid is not flowing in hopper all the way. It stops and starts bubbling at the top. Nothing is blocked, reassembled several times with/without face plate. The water will only go halfway in the hopper. No type of blockage. can someone offer any ideas, suggestions. Im lost
Oct 09, 2010 | Taylor Ice Cream Makers
My taylor freezemaster ice cream machine does't work properly
I can not get the plugs out of the back of the machine. In the hopper
Jul 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Taylor soft serve ice cream machine model #y754-27
I have a gearbox,coupler,pulley etc. pulled off a y754-27
Jer 805-925-5556
Sep 30, 2008 | Taylor 632-33 Ice Cream Maker
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
