I have coby dvd 283 player , its new but i don't know why it is nt playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If
the unit is showing "invalid disk" on every disk that you try to play,
unfortunately, the unit has developed a defect and needs to be
replaced. Our warranty is 90 days from the date of purchase. If you've
had the player longer than 90 days, I regret to inform you it is out of
warranty.
If you feel this solution doesn't deserve a good
rating, please let me know why so that I may better assist you. If
there is anything more I can do to help, I will!
Try to use a different dvd because that one might not have been burned or made in the right format. If that doesn't work, then try blowing on the laser just in case there is dust on the lens causing it not to read the dvd properly. If that doesn't work, then you might need a new dvd player.
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283 1. Open DVD Tray 2. Press the “Menu” button 3. Press 8888 4. Press the “Display” button 5. Region Code Number shows up. Use the numeric keypad to select your region code number 0 6. Press the “Setup” button to exit.
DVD283 1) Open DVD Tray 2) Press STOP 3) Press 70 plus region code 0 Example 700. Region 5) Wait five (5) seconds; the unit will automatically exit the region code menu.
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
i have coby dvd 283 player , its new but i don't know why it is nt playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
