Question about GPX Audio Players & Recorders
VM-i 1011 I have VM-i 1011 and all of sudden no sound comes. CD/ Radio/ Card / USB - All seem to run, but no audio in speakers or headphone.
Paeroa
  • 457 Answers
SOURCE: no sound from headphone
There isnt any problem in your laptop. What on earth made you think there was? Your problem is the headfones are stuffed at least that is how you explained it throw them away and get some more??
Posted on Sep 29, 2007
map9966
  • 2351 Answers
SOURCE: M2A-VM Audio problems
Asus does have Updated software for, Realtek ALC883 Audio Driver V5.10.0.5404 for Windows 2000/XP & 64bit XP (WHQL).
Dated: 2007/09/24
There is also an update for the Bios which includes an Update Realtek PXE ROM to V2.08 dated 2007/12/4. To look at these updates & others click the link below. The link will open to your board with Linux opened. Just click, Latest or All at the top of the window.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2A-VM&type=map&mapindex=7
If the updates do not help remember your board is warranted for three years through Asus. You can call Asus Tech at: 812-282-2787. IL EST. It sounds to me that the onboard audio chip is going. I checked all FAQ's & found no complaints about the onboard sound.
Hope this helps & leads to a fix..
please vote... Luck!
Posted on Feb 16, 2008
  • 5 Answers
SOURCE: macbook 2 ghz white no sound
this has been answered, just stick something small in the headphone port, best to save money, or take in a local apple store.
Posted on Jun 13, 2008
darjr
  • 378 Answers
SOURCE: Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
Posted on Jun 01, 2009
  • 8 Answers
SOURCE: My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to creative.com and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Posted on Jun 06, 2009
Why am I not getting sound anymore?
Amplifier issue. See if you are getting audio signal at audio outputs used for recording. If not, then it is NOT the audio amp and the proceeding circuits are responsible.
U might also want to check out your power supply voltages to make sure that the other components are being properly fed.
Feb 05, 2016 | Denon DRA-397
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
I have an LG fb163 everything seems to function but no sound in the speakers
check mute button, source knob/button, speaker selection knob/button while its playing a cd or FM radio. Also if you have connected headphones the speakers would mute. Check the speaker connections. If the speakers are powered you need to connect them to a power source. If all these fail to produce sound consult a technician.
Oct 30, 2014 | LG FB163 DVD/DivX USB Micro system Shelf...
I have HP-Pavilion- DV2000 Laptop I have a sound problem because sound not coming out from built-in speakers, headphones or external USB speakers. Drivers in device manager seems to be OK Sound play cursor...
sounds like it can be the hardware. try to uninstall and reinstall the latest audio driver then configure your speaker settings and volume settings. if this does not work, you may need to get the audio card or motherboard replaced.
May 15, 2011 | HP Pavilion ze2000 Notebook
Audio is install but not work?
good day sir, hi, check your speakers audio wire, it migth be open, to test, plug your speakers, on a portable mp3 player, or another pc with sound, if your speakers are good then it could be any of the followings:
  1. your sound driver installed is not correct, or incomplete, locate your CD driver disk and run it again.
  2. If you cannot find your CD, download the driver from this site: http://www.jetway.com.tw/evisn/download/driver/index.htm#865
  3. If you have the CD, and still your sound card does not work, check your sound card status , right click my computer, properties, hard ware, then device manager. look at the sound video and game controller. Ig it has (!) or (?) means that there are hardware conflicts. You need to reinstall windows to solve these conflicts.
  4. If still no audio, check your sound card, or swap out a good sound card and see if it will work.
  5. If still no sound and all sound card seems not to work. get a USB sound card, plug in the USB sound card and thats it. If it has a CD driver run the CD.
Let me know your progress.
Nov 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Jun 06, 2009 | Audio Players & Recorders
Toshiba Satellite Laptop - No sound when connected to earphone
possible solution: go and check your audio properties. the line-out might have been disabled, muted or simply turned down.
May 25, 2009 | Toshiba (4CH-VOUT) Sound Card
Audio volume keeps changing by itself
No, the headphone output is designed for 2 speaker output. Just recently I had a customer who had no sound coming from the desktop speakers yet the headphones worked just fine.
I believe that your model has a sound circuit integrated into the motherboard. It may have a “plastic cap” covering the audio ports (next to the USB ports). If you remove the sound card and enable the integrated audio in the BIOS, you can check to see if the sound card is actually the problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Noise in my speakers
you need to go to asio config and open the controls tab and mute the first two channels on the left hand side you will hear your music without the humming noise.
Oct 18, 2007 | AudioTrak MAYA 44 USB External Sound...
116 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
