Question about Rosen inVUE II Video Ent. Sys '00-'02 Chevy Suburban w/o Sunroof
Invue system for an 02 suburban.
I have an 02 suburban, no owners manual. It has an invue tv system with vcr. the vcr and tv picture works but no sound. Is the sound system hooked up throught the radio, or is it independant.
    Problem Solver:
First you can download a manual for your model from Rosen's site. It explains all the on screen programing you can do. You'll need a fundtioning remote to do this I think. You can get one from a local Rosen dealer for about $35 (see deaker finder on Rosen's site. Yes your sound does come through the radio on 88.7 or 88.9FM througha modulator installed inside your dash. Otherwise you use infrared wireless earphones (Wal-Mart sells them). The "Speaker" button on the passenger side of the LCD screeen turns the car speakers on or offf.
Posted on Jan 17, 2009
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
2000 suburban sunroof wont close
My sunroof did not close all the way, but would work back and forth. I postitioned the sunroof half way, disconnected the battery for 1 min then tried it again. The system that keeps track of where the sunroof was positioned got reset and it now works great.
Feb 03, 2009 | Rosen inVUE II Video Ent. Sys '00-'02...
Car won't start
your neutral switch is in your gear shift. it's just a little button on the shifter if it's an automatic... and if standard it''ll engange when you push the clutch in... your ignition switch might be fried if you are turning the key and the wire is getting no power..
Mar 11, 2008 | Rosen inVUE II Video Ent. Sys '00-'02...
'02 monte carlo ss problems
if you give gaz its shake if you let go the gaz does it still shake if it still skake it probably wheel balance if it shake in the stering its the front if you feel it in our seat its the back but if it vibrate only when you give gaz it could be a cv joint or universel joint cheers
Jan 28, 2008 | Rosen inVUE II Video Ent. Sys '00-'02...
Problem
1. Check fuses
2. Check Cables
3. Check mechanical Damage to units including swtiches.
Dec 14, 2007 | Rosen inVUE II Video Ent. Sys '00-'02...
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Car Audio & Video Logo
274 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
