Question about Sony CDX-L400X CD Player
Can i play an ipod from a sony cdxl400x car stereo
How do I play iPhone on Memorex m1111
I plug my iPhone into the Memorex Stereo (which has an iPod ...
discussions.apple.com > Support > Apple Support Communities
AppleJun 2, 2012 - I plug my iPhone into the Memorex Stereo (which has an iPod function) and the music is not playing on the speakers. My son's iPod does work ... Memorex recorder-burned DVD's won't play on iMac
Sep 21, 2013
ipod touch will not play through dock speakers
Aug 16, 2010
More results from discussions.apple.com
Amazon.com : Memorex Home Audio System with iPod ...
www.amazon.com/Memorex...Player.../B0017Q6HB...
Amazon.com, Inc.Amazon.com : Memorex Home Audio System with iPod Dock and CD Player ... Sony ZSS3IPN Lightning iPhone/iPod Portable CD Radio Boombox Speaker Dock .... but there is a cord for FM radio reception and I'm sure if I play with it, I can get ...
Amazon.com : Memorex MI3602P PurePlay Portable ...
www.amazon.com/Memorex...PurePlay.../B0040YGJ...
Amazon.com, Inc.
Jan 10, 2016 | Cell Phones
PLAYING IPOD THRU SYSTEM
i think you will have to try a new adapter for getting this problem fixed.
please use a new one
Sep 29, 2008 | Pioneer DEH-P4600 CD Player
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
How does iPhone play on it
Cd Player With Ipod Dock: Amazon.com
www.amazon.com > ... > Stereo Shelf Systems
Amazon.com, Inc.When searching for cd player with ipod dock products, Amazon customers prefer the ...Sony ZSS3IPN Lightning iPhone/iPod Portable CD Radio Boombox Speaker Dock (Black) .... Even on the highest volume, the sound does not crack.
Play music from your iPhone in your car - Macworld UK
www.macworld.co.uk > ... > Play music from your iPhone in your car
Nov 11, 2014 - Here are some ways you can play the music from your iPhone in your car. ... can't put a fake CD connected to a stereo cable in your CD-player: ...
connect iPhone to in car CD player ' Apple Support Communities
AppleJun 24, 2008 - Don't know about CD player, but this is about the cheapest/easiest way to ... -iPhone-F8Z182/sem/r psm/oid/210337/rpem/ccd/productDetail.do How do I insert a CD to the iPad 2?
Apr 17, 2011
Imported CDs - poor quality
Jan 18, 2011
Playing music on iPHONE in car
Sep 6, 2007
Jan 10, 2016 | Audio Players & Recorders
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
Cannot play ipod touch on car stereo
hi there
You will need one of theses:
Click Here
This is a USB to Stero adaptor... will fix your problem for you.
hope this helps
alex
Apr 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
Playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
Jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Cheers
Aug 20, 2008 | Jensen VM9510 Car DVD Player
Sony CDX-L400X CD Player Logo
41 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
