Question about GE 26928GE1 Cordless Phone
Battery holds a charge for a short time only
Replaced battery about 2 weeks ago. Charge does not seem to hold for long. Measured base output voltage to phone at approx 10.4 vDC. Is this correct or in range? Measured battery voltage after attempted recharge is approx 2.3 vDC. Would this be symptomatic of inadequate charge time - 12 hours?
    Champion:
    Filmmaker:
    Uploaded 5 video answers.
  • 271 Answers
These phones are known for the contacts not transferring adequate voltage to fully charge the phone.
Posted on Oct 23, 2008
My makita battery is not taking a charge is it the base or the battery
The most easiest way to be sure is using multimeter. 25290419-3h5pkc2unruv115jj1tsixdi-2-0.jpg
Set your multimeter to highest dc volt. All chargers have output voltage information written on it (Must be written as "output" value or "sec"). Measure charger's output pins (which connects to battery) and be sure measured value matches with output voltage value written on charger label. If it doesn't match each other, buy a new charger and proceed with below part.
Discharge your battery. Once you discharge battery; be sure that there is no charge at all. Charge battery for 15 min. Measure battery power with multimeter again. If there is no charge at your battery, it is dead and you need another battery.
Nov 19, 2014 | Makita Drills
Invacare battery charger 24 volts no output if not connected to battery?
If the battery has stood for two years with out a charge it will no longer be able to hold a charge renew it . most modern chargers need to detect battery voltage before they will charge .
Sep 17, 2014 | Health & Beauty
Will not hold charge and voltage gage is not working
Is the alternator putting out a charging current when running? Measured at alternator then at battery. If no at alternator, replace alternator if high mileage, if low mileage replace regulator. The part the harness plugs into.
If yes at alternator and no at battery, check for continuity across ammeter and check the voltmeter for a short. The ammeter should read essentially zero ohms and the voltmeter should read about 15,000 to 40,000 ohms when measured with an analog ohm meter.
If those check okay, check for a wiring fault or a blown fuse on the power distribution block or a broken fusible link. Fusible links can be checked by gentle tension on them, those that have failed will pull apart.
Jan 18, 2012 | Cars & Trucks
Mower runs great, problem is battery goes dead, its a new battery, i recharged it, measured the voltage at 13.41, started it, it measured 14.47 volts then drops a few decimals every minute like 14.42 after...
Try disconnecting the battery and note if the voltage drops.
If it does, the battery is not holding a charge.
If it keeps its voltage, the problem lies in a minor short in the mower.
You have to determine which item has the problem first.
Is this helpful?
Gary
Feb 28, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I replaced the battery 3 weeks ago and everything has been fine. My wife drove around everywhere on Friday. She did not drive the van yesterday. It is now Sunday night. My wife went out ot start her van...
Your alternator is going bad. It should only put out 13-14 volts and therefore is overcharging your battery. This causes your battery to get a dead cell. If you replace the alternator and battery, make sure you check the cables for any shorts.
Aug 31, 2009 | 1991 Ford Aerostar Extended
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
EI Systems 3085 Laptop will not charge battery
Yuo should measure the voltages from the charger not the PC.
May be the charger is broken.
Mar 21, 2008 | Computers & Internet
Battery not holding charge
THAT IS AN ERROR ON YOUR BATTERY METER YOU NEED TO DO A HARD RESET AND IT WILL CORRECT THIS PROBLEM...*2767*3855#
Oct 28, 2007 | Samsung SGH-D900 Cellular Phone
GE 26928GE1 Cordless Phone Logo
501 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
