Question about Apple iPod nano
Frozen iPod iPod screen shows a big check mark with the message "Disk Mode" at the top of the screen and "OK to disconnect" at the bottom of the screen. iPod will accept a command and is literally frozen................. How can I unfreeze it?
Move the lock button back and forth then hold the center and menu button at the same time for seven seconds. =)
Posted on Oct 24, 2008
Its stuck in disk mode screen displays a check mark that says ok to disconnect player wont turn off or go to menu screen
Try resetting it. Hold down the middle and menu buttons at the same time and it should reset itself. Then it should go to the main menu. Good Luck!
Jul 08, 2010 | Apple iPod MA446LL/A MP3 Player
My old style nano 2g has disk mode displayed on it - ok to disconnect.... appears frozen
This solution for the ipod white screen of death also has how to get out of the disk mode
http://www.zolved.com/synapse/view_content/19067/The_Apple_iPods_White_Screen_of_Death
Nov 12, 2009 | Apple iPod nano
Unlock ipod
Check the top lock switch.
If it's frozen, press the center button and the bottom button at the same time and hold it until you see a white apple on the screen. if it's an IPOD shuffle, i have no idea.
Sep 18, 2009 | Apple iPod shuffle MP3 Player
I woke up this morning and noticed my IPOD nano silver 2GB displaying a disk mode pn th top of the screen with a huge checkmark in the middle of the screen and the phrase ok to disconnect on the bottom of...
Reset Ipod.
Make sure power switch is on.
Press and hold center button.
next press and hold "menu" on the ring.
When a Apple logo appears on the screen let the buttons go.
Should take just a few seconds.
May 04, 2009 | Apple iPod nano
Ipod nano has a message on the screen that reads ''disk mode''
Salut, j'ai quelques problemes avec mon ipod Model A1137,2GB c'est que j'ai oublié le corde
Feb 24, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Ipod Nano 8gb won´t synchronize
Try this.
  1. Put the iPod into disk mode by holding the menu and middle keys together until the screen turns dark.
  2. Then quickly hold both he middle button and play/pause buttons until the iPod shows a check mark and the words disk mode at the top.
  3. ThenClick on iTunes to open it.
  4. Connect the iPod to the computer. You may have to do a restore depending on what iTunes says you need to do.
If this doesn't work, check the bottom of the ipod where you connect the cable. See if there are any bent pins. These are very fragile and can be damaged if you insert or pull the cable out the wrong way. Hope that helps.
Dec 19, 2008 | Apple iPod nano
My nano won't restore.
Try putting the ipod in disk mode by pressing the center and play buttons after resetting it (by holding down the center and menu buttons). You will know it is in disk mode when it shows a check mark on the ipod screen. Then plug it into your vcomputer and format it using windows.
After you format the ipod, try disconnecting and reconnecting to the computer and restore and see if that fixes your problem.
Jan 30, 2008 | Apple iPod nano
Frozen on the ok to disconnect screen
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 12, 2008 | Apple iPod nano
CheckMark On My 1-Gig Nano
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Nov 10, 2006 | Apple iPod nano
Apple iPod nano Logo
325 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
