GA-EP41-UD3L problem with SCSI/IDE
Hello everyone. I have a little problem. My 2 hard disks in the computer (physical HDD's) are connected by PATA IDE and they work fine. They're both connected to motherboard GA-EP41-UD3L connector. Both boot fine (I have Windows 7 Ulti on one and Windows Server 2008 Standard on the other one). My DVD drive is, however, a different story. Since I have only one IDE port on the motherboard, I was forced to buy Via SCSI IDE card controller for my DVD drive. It works perfectly fine when connected to my ASUS DRW-1814BL THROUGH WINDOWS. However, whenever I want to boot the disc before entering Windows selection boot, the drive doesn't start boot from the disc. I did set the boot options (1st CD/DVD drive) and it still fails to do it. It proceeds to boot from the HDD drives. I changed the cables to see if the card controller might be faulty, but it's working fine. I set the IDE cable from the card controller to one of the HDD, and the other HDD to the IDE port in the motherboard. Only one HDD (the one going to the motherboard) is recognized. However, inside Windows, I can access both HDD's. This concludes that the card controller is indeed not faulty and working well. What should I do? Help!
  • 2 more comments
  • kyonyan Feb 11, 2012
    The main question is: What do I do to boot DVD bootable disc outside of the OS?
  • kyonyan Feb 12, 2012
    Thank you for your solution Stuart. Sadly, when I connect DVD and HDD, it slows down the HDD rate significantly. I don't know how to approach it anymore. Isn't there any way to make BIOS see my DVD drive?
  • kyonyan Feb 13, 2012
    Stuart, that's a great observation. I thought about it myself as I saw 4 SATA slots on my MB. However, my ASUS DRW-1814BL drive doesn't support SATA connection. As said on the ASUS suppport webpage:
    Q: "What's the difference between DRW-1814BL and DRW-1814BLT?"
    A: "They differ in the interface: DRW-1814BL is with PATA and DRW-1814BLT is with SATA interface."
    It's amazing what one letter of difference can do... haha (that's some auto-irony there).
    Getting a new DVD drive huh... I guess I should consider that. It would make sense tho. I could connect new DVD drive to SATA, and let PATA deal with the first 2 HDD drives. Also, if I get new ones, my VIA card could take care of those (since I won't be having any system OS on them, they might as well just be used inside the OS interface).
    Two heads are always smarter than one.
    Thank you very much Stuart!
    P.S. Went out and bought a new (and cheap!) LG GH22NS50 drive and it works wonderful. Thanks for your input on the matter. I really appreciate it!
  • 807 Answers
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Posted on Feb 12, 2012
Testimonial: "Thank you Stuart!"
  • Stuart
    Stuart Feb 13, 2012
    The only other option I can think of is if you changed your DVD Rom for a SATA drive instead of IDE. I just looked at the motherboard on Gigabytes site and noticed it has 4 SATA sockets on the board.
Physical disk not found
Move into Raid Controller bios (ctrl +c)
Check other hard drives are visible.
If yes, you may insert disk in other free slot and see if it detects on that slot. If same issue then particular hdd may be faulty. You have to replace it
If no, turn off server, reset scsi and power cables.
Turn on server and see if it detects hard drives. If server has same issue then either scsi cable or hdd back plane may be faulty. Chance is more for hdd back plane
Thanks
Oct 15, 2013 | IBM X236 Server
MSI K9VGM-V Motherboard problem or maybe the disk-drive?... please help me!
Except in rare cases where you and your friend happen to have computers with the same motherboard (or something really close), exchanging hard drives like this will not work. When windows is installed, it installs the drivers for the computer's specific hardware. If you move the hard drive to a different computer, Windows will try but fail to load because it does not have the drivers it needs.
On a friend's computer, go to this site: Microsoft Windows and Office ISO Download Tool
follow the instructions and you can download the ISO to burn a copy of your Windows disk. There is a sticker on your computer that will have your original ***********. This *********** will only work with whatever version of Windows came with the computer.
Note: If there were important files on your old hard drive, do not use it. An expert can possibly recover your data. Forget about the IDE drives and get another SATA or the speed will drive you crazy. IDE has data transfers at the rate of up to 133MB/s while SATA has data transfers at the rate of up to 6 Gb/s
IDE vs SATA
From the age of the motherboard, it looks like you probably had Windows XP which is no longer being supported. See bottom link.
Have you considered trying something like this:
Main Page Linux Mint
It can actually be installed and run from a CD or flash drive so you can try it. If your old hard drive is connected and the file system has not been damaged, you can even use this to copy files off before you reuse the hard drive.
https://www.microsoft.com/en-us/windowsforbusiness/end-of-xp-support
Mar 01, 2017 | MSI K9VGM-V Motherboard
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
Gigabyte GA-EP41-UD3L Intel G41 (Socket 775) the motherboard doesn´t run with an ati hd radeon 4650 gddr2 1gb constantly rebooting already tested with another ati hd radeon but gddr3 and runs can...
The card needs to be connected to a power source within the case, the main power supply, otherwise it will shut the computer down when it overheats. Make sure the fan on the card is moving.
Apr 12, 2010 | Intel Computers & Internet
During initial configuration and build of the system, when the system tries to boot it recognizes the IDE hard drive but places it on channel 4. That's as far as it gets, it will not boot into the...
Try changing the settings on the BIOS, like drive configuration and boot sequence/priority. also check the jumper on the OS HDD and make sure that it is on Master.
Sep 27, 2009 | Gigabyte GA-EP45-UD3L Motherboard
Gigabyte ga-8i915p duo motherboard ide problems
RAID stands for Redundant Array of Inexpensive Disks.
The RAID system uses multiple number of hard disks to give a fast and fault tolerant storage using several disk controllers.
There are various levels of RAID, for info on RAIDs check out
http://en.wikipedia.org/wiki/Standard_RAID_levels
Apr 03, 2009 | Asrock P4VM8 Motherboard
Setup did not find any hard disk drive on your computer
Just look for the BIOS set up and I,m sure you will solve your problem, or plug the IDE cable properly...
Dec 21, 2008 | ASUS P5GD1-VM Motherboard
Hdd installation
The capacity that a motherboard can support is designated by the BIOS.... a few years ago when HDDs started to get big, there was an issue in supporting disks above 137GB as this exhausted the old HDD addressing system..(BIOS), to rectify this the BIOS code was re-written to support 48bit LBA (Logical block addresses) so as long as you have up to date BIOS for this motherboard, it should be alright.
you should be able to install any capacity available on IDE as long as you have updated the BIOS to the latest version (check the Giga byte website to download this)
If you wish to upgrade your PC further you can get a SATA/PATA adapter, or you can get a PCI SATA, IDE or SCSI controller card. Effectively there are very few limitations to the number of disks nowadays.
Dec 05, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Computers & Internet Logo
231 people viewed this question
David Payne
David Payne
