some songs will work, but vast majority say I need liscense agreement, (which all have)some songs will work, but vast majority say I need liscense agreement, (which all have)
You can't post conmments that contain an email address.
thats because the itunes files are formated to .acc and not mp3 and may be right protected you can try and convert them to .mp3 and they might work try it and if not then there right protected
Ilo player must be synchronized, coping and pasting files is not enough:
Start Windows Media Player and select following menus: "File.", then choose "Add to Library." then the "Add"
button. Then, look for the folder where your keep the mp3s to upload.
Plug the Ilo MP3 player into USB.
Click the "Sync" tab that you find at the top of Windows Media Player . You will find the Ilo MP3 player on the right side of Windows
Media Player. If Ilo is not ther, then right-click on Sync tab and
click "Refresh Devices."
Click
"Library" then
"Songs." on Windows Media Player . Highlight the son songs, and choose "Add to
Sync List."
Click
"Start Sync" button that will appear at the bottom right corner of Windows
Media Player. The songs will then be uploaded to the Ilo MP3 player.
You can't use Limewire directly to transfer songs to the Nextar. You will need to transfer the songs to the Nextar using Windows Media Player. Limewire puts the songs in a folder called "Limewire Downloads" usually. You will need to open Windows Media Player, run the mouse over the "Library" tab, and select "Add to Library." Once the window pops up you will need to add the folder called "Limewire Downloads" - it may take several minutes, but Windows Media Player is going to add all of those Limewire downloads to its own library. Then, you can use Windows Media Player to transfer the songs to the Nextar.
That's a DRM error and should be solved by the FairUse4WM which you can download for free from the following link.: http://undrm.info/remove-DRM-protection/FairUse4WM-freeware-DRM-removal-Windows-software-Strip-copy-protection-from-WMV-ASF-WMA-Windows-Media-Player.htm This will rip the DRM off the tracks and you should be able to sync it or listen to it without a problem.
it is look like it is psword protected ,or has some kind the buton wich does not let you put/remove song's fom it.try to find that buton or rest to factory seting, format the player.
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON. o You must use Windows XP and Windows Media Player 10 for online purchased songs. o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files * You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON. o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
well songs u dl may be protected ok or if uuse windows player 11 to trafer on hd set the settings at mp3 128 bit rate in options then trafer at that not wma those will be protected in players ok thx nick
Here's how you get it
you may have to open Windows Media Player but maybe not
a screen will come saying for you to choose either NO leave all the media on the device... or YES delete all media.
click YES but MAKE SURE you have the HOLD button on OFF. if you dont... it will not work
after it completes the task click FINISH
i tried for hours trying to figure it out and that made it work like a charm! =]
