The local electricity supply went off and when power was restored the computer would not come back on again. What has happened?
  • Computers & ... Master
  • 5,660 Answers
Could have been a voltage spike. When the utility company turns the juice back on, there is a rush of power. This is needed to meet the power demands for all the users, who are on the line.
Problem is the voltage may be higher than what is needed, and a spike may occur. (Spike: Temporary voltage increase )
No sir. The utility company is not held responsible. (Yes, that bites!)
I have found that around 80 percent of the time, the problem is a bad Power On switch, or a bad Power Supply, when this occurs.
{The rest of the time the power went further than the Power Supply, and burned out the motherboard, Processor, Ram Memory, etc}
Power Supplies used in desktop computers, are generally a generic low quality unit.
Low quality Electrolytic Capacitors, Rectifier Bridge, MOSFET's, small gauge wiring, etc.
Couple that with some age on the Power Supply, and it doesn't take much to put it in an 'early grave'. (Plus being dirty inside)
I suggest you test to see if the problem is a $5 ATX power on switch, or the Power Supply.
I can only give you generic information, as the computer manufacturer name, and model number were not given.
(It's on the back of the computer tower next to the Windows product key, or up on the side/top of the tower, or behind a hinged panel in the front of the computer )
The test is to use a jumper wire, and bypass the Power On switch.
This has Nothing to do with the switch itself, however.
The main power cable coming from the Power Supply, and plugging into the motherboard, is either a 20-pin ATX main power cable, or a 24-pin ATX main power cable.
(Unless the desktop computer is Real old)
1) Basic example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
{NOTE* Color of connectors does Not matter }
2) Basic example of a 24-pin ATX power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Same thing about color)
Here's the way it works when you press the Power On button, and the computer is plugged into power;
The Power Supply, when plugged into power, has a constant 5 Volt standby power present. (DC)
Pressing the Momentary Contact Switch of a Power On switch, momentarily routes the 5 volt power present in the Power Supply, back to another circuit in the Power Supply.
The Soft Power On circuit.
This small voltage 'excites' the Power Supply, and turns it on.
(No pun intended)
As stated, the Standby power is 5 Volts.
It is 5 Volts DC. In comparison two D cell flashlight batteries store 3 Volts DC.
Stated in case you are worried about electrical shock.
(The Power Supply in your computer is a SMPS.
Switched-Mode Power Supply.
It converts the AC power from your home, or business, into three main low DC voltages.
3.3 Volts, 5 Volts, and 12 Volts.
No matter if your country uses 100 Volts AC, or 120 Volts AC, or 220 Volts AC )
Look at either ATX main power cable. Note in the photo to the far right, the power cable is shown plugged into the motherboard. This is how it should be for the test.
Note also that the wires go in the BACK of the connector, and there is one Green wire.
This is the Soft Power On wire. (Can be abbreviated as PS_ON)
ALL of the Black wires you see are Ground wires.
The preferred jumper wire is a paper clip. It is straightened out, then bent into a U-shape.
The U is wrapped a few times, with black plastic electrical tape
for your fingers, and thumb to hold onto.
The 'legs' go down into the socket holes, in the BACK of the ATX power cable's connector.
The jumper 'legs' go down in the socket holes, RIGHT NEXT TO the existing wires already in the socket holes.
Right next to the GREEN wire, and ANY Black wire.
At the end of every wire going down into the back of the connector, (ATX main power cable connector) is a metal terminal.
This metal terminal is pretty far down in the socket hole. (1/2 inch?)
The jumper wire MUST touch the metal terminals.
The contact made is temporary. No longer than 2 seconds.
(Power Supply plugged into power)
IF, the Power Supply comes on, you have a bad Power On switch.
IF, the Power Supply does Not come on, you have a bad Power Supply.
The Power On switch, is located inside the plastic Power On button assembly.
It is an ATX Power On switch.
This is one example,
http://www.directron.com/atxswitch.html
The plastic of the Power On button assembly gets hard over time, and with constant heat from the computer.
The best method I have found, is to remove the Front Panel, and the Power On button assembly.
[ NOTE* Make notes as to which pins on the motherboard, in the Front panel header, the wires of the Power On switch go to.
I may Not have access to the Front Panel header pinout, to tell you where those wires went.
{The plastic front of your desktop computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header ]
I then use a hairdryer, or a bowl of very warm water, to soften the plastic.
(The ATX power on switch inside is going to be thrown away. Doesn't matter if it gets wet )
Then carefully ease the case of the Power On button assembly out, and ease the ATX power on switch out.
There MAY be a spark as you connect the jumper wire. Letting you know in advance. The tape is to protect your fingers.
You may feel safer using a glove on that hand.
The voltage however, is 5 Volts DC. As previously stated two D cell flashlight batteries store 3 Volts DC.
Would appreciate it if you would post back in a Comment, as to your findings.
With the computer manufacturer name, and model number, I may be able to show you direct information.
I can also help you decide on a Power Supply to buy, should it be the problem.
Regards,
joecoolvette
Posted on Feb 12, 2012
Bunkerhill wireless security camera screen went off want come back on
_won't_ come back on. I see so many people on here using the word 'want' instead of 'won't', which is an abbreviation of 'will not'. Strange, never seen it happen in the UK.
check the power supply to it. They are pretty simple all they need is electricity which his supplied through a cheap made in China power supply unit.
Jul 21, 2016 | Home Security
My power went out in my house and when the power was restored my computer would not turn on...there is a blue flashing light in the back of the computer.
The blue flashing light is probably on your power supply. I suspect that the power supply was subjected to a voltage surge during your power outage. It may have damaged your power supply (or possibly other components in your computer)
Try unplugging the power supply from the wall socket and leave it unplugged for at least 5 minutes. Then plug it in and see if your computer will turn on. If it will not, you require the assistance of a PC technician to test your power supply and computer.
You should connect a surge protector or UPS (Uninteruptable Power Supply) to your computer to prevent this from happening again.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Dec 31, 2010 | HP Computers & Internet
Due to an electrical outage,desktop computer (Sony Vaio VGC-RB30), lost power and would not reboot. A small blinking green light on the back panel was the only thing happening. Is this a hard disc problem...
this usually mean the power supply went bad and is in safe mode.(so other component in the computer won't get damaged) try unplugging the computer from the wall and wait 10 minutes. If you plug it in and the green light is still flashing the power supply is the most likely thing that is wrong. you can take the power supply to a local repair shop and they can test it in a few seconds. my guess is that it is bad. (please rate)
Dec 21, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
After a power outage computer will not turn on
first of all what kind of computer is i mean brand? secondly sounds like the power supply went bad..
Jun 12, 2010 | Computers & Internet
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
My computer wont turn on
Remove the power cable and hold down the power button for about 30 to 60 seconds. plug the power back in and see what happens. If fail look at the back of your computer ans make sure that the fan for the power supply is on. Also make sure that the red switch is set to 115V and not 220V. This is also located in the power supply.
If al has failed your power supply is no longer working and will need to be replaced.
Apr 22, 2009 | E-Machines eMachines Desktop PC
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Computers & Internet Logo
David Payne
David Payne
