Minolta dialta trouble code c0650
When pressing copy code c0650 comes up and nothing happens.
is there a reset button or function ? i have not been able to find description for trouble code c0650
minolta dialta di250
nabrahamn@yahoo.com
  • sam gerban
    sam gerban May 11, 2010
    could you please verfy code for me?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Posted on Dec 18, 2008
Menolta di650 sc 46-25 sulotion ?
Posted on May 10, 2013
Minolta dialta di620 error 14ao hilp me
Exposure lamp header failure. The exposure lamp is the bright light under the big sheet of glass the comes on to make a copy. Raise the Document feeder and press the start button does the bright ligt come on.
To reset open the front door in the upper left is a small access panel open press the trouble reset. if the code comes back replace the exposure board and lamp
try this place as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 09, 2015 | Minolta DiALTA Di620 All-In-One Laser...
How can i remove error code in dialta 2510 is show c0500 error
Sir/Mam, First ensure the right side cover is closed correctly closed also check that the two latches that are located on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can never use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code you messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Jan 22, 2015 | Minolta DiALTA Di520 Laser Printer
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0510
First ensure the right side cover is closed correctly closed also check that the two latches that on the door are not brock especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copier Man look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code you messing with is for the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it. The Di250 is a Minolta Legacy machine. if code comes back The fuser unit is bad a needs to be replaced. IF you can find one A technician mite be able to get the internal parts of the fuser and rebuilt it
Jan 08, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Di 3010 error code dialta SC 520
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that is OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Jun 27, 2013 | Minolta Di3010 Copier
Co501
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Apr 22, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
Code c0510 in dialta 520 how to reset
open the front door, upper left small access cover remove. press trouble reset. if the code comes back do not reset problem with the fuser continue reset fuser can catch one fire the will ruin a perfectly good day. have the fuser checked out.
Feb 02, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
C-0400 Minolta DiALTA Di520 Laser Printer
Exposure lamp failure (Burned out or the control board that controls it. The EXPOSURE lamp is the very bright light that comes on below the big glass on top. Reset the code open the front door to your left is small access remove it press the trouble reset button if the code comes back get a new lamp try the web site below for a start
Oct 06, 2011 | Minolta DiALTA Di520 Laser Printer
How to reset the co500 error code from my minolta dialta di250
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
For a new fuse try this site for a start
forf Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Sep 30, 2011 | Minolta DiALTA Di250 All-In-One Laser...
C0650: Faulty PC12 C0651: Faulty PC13
Relevant Electrical Parts Scanner Home Position Sensor 1 PC12 Scanner Home Position Sensor 2 PC13 Scanner Motor M5 Master Board PWB-A BCR Board BCR HGB Board HGB MFB Board UN2
Nov 06, 2008 | Minolta DiALTA Di250 All-In-One Laser...
845 people viewed this question
k24674
jasbo
jasbo
