Question about Gigabyte Computers & Internet
Hi I have just assembled my rig but when im installing my OS it doesnt detect my Sata3 Hard Drive. My motherboard is GA-z68ap-d3. Please help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Try changing port or the cable ...check in bios if sata is enabled or disabled...to enter bios u will see an optin when u switch on the PC...
Posted on Feb 11, 2012
How do i get my sata ports on my motherboard to work?
Hi there. I think your board is an early SATA board as it has IDE connectors too. I am not able to access the website you have listed but have had a fair bit of experience with SATA drives on such boards. It might well be that there is an option in your bios to switch between native SATA support and IDEmode. If you can find such a facility in bios then try changing it. You should try the drive on another machine to ensure that it is not defective, if the drive is a new one then try it on a very recent machine.
The issue might that the hard drive is not compatible with your board, some SATA3 drives will not work on older boards. The is true of some SATA2drives. It might just be an incompatibility issue.
Good Luck
Feb 10, 2015 | Computers & Internet
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Hitachi Deskstar causes a Power Error on my Gigabyte GA-Z68AP-D3
test all leads that attach to your hard drive including electrical extensions, SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
make sure the CPU central processing unit has thermal grease and a dust free secure seating
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
could be a memory dump you might have to many programs running at one time putting to much stress on the CPU not having enough ram will do this
might be getting to hot make sure the CPU has a dust free secure seating and has THERMAL paste
if you right click in the bottom toolbar select task manager applications you will see whats running also processes you will see whats ticking over if you see something running that should not be select end now you might even uninstall that program and some unnecessary programs
check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
May 08, 2012 | Hitachi Deskstar 35 1TB 7200RPM SATA II...
USB 3.0 connectivity to front on GA-Z68AP-D3
As you said the board got the front pin connectivity.
All you have to do is buy in any comp shop a front USB and sound socket for the casing.
It is up to you where to put it on the front panel, drill a hole to fit that outlet and use hot glue to fix it in that position.
Hope that helps!
Nov 21, 2011 | Computers & Internet
When my PC starts, I get a long beep 7-10 seconds followed by a delay of about 20 secs and then repeats. The OS will not boot, I have tried changing the RAM, which worked once then same problem. The RAM...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 22, 2010 | Gigabyte GA-VM900M Motherboard
My Motherboard wont recognize my Hard Drive
Is it Sata or IDE?.Also is your boot order set to the CD rom as the first device.The O.S is bootable only if the CD runs it first. Windows should format it later in the install process.
Nov 25, 2008 | Computers & Internet
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
My motherboard can;t detect my harddisk.....
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Sep 01, 2008 | Gigabyte Computers & Internet
Please help... i am installing a new sata hard drive but it is not detected...
Please give us more information.
1. How old is your PC?
2. Size of your old & new hard drive.
3. CPU speed, motherboard brand & model.
If your motherboard unable to recognize the size of the new drive. then, you can find BIOS update for you motherboard.
Mar 18, 2008 | Intel Motherboard
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
Open Questions:
Computers & Internet Logo
49 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
