Question about HP LP2275W 22 inch Monitor
HP LP2275w monitor problem: vertical colour lines, can you help me?
I bought this monitor 3 years ago. I tudned it on a week ago, ang I got a screen like that. How can I repair it? There is a picture, how it looks like: http://n1.vatera.hu/photos/8e/ca/f1c5_1_big.jpg Thanks for your answer!
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
  • 4 Answers
SOURCE: HP W1907 Monitor
you might have to re install your driver, unplug your monitor and then use your older monitor to uninstall driver, then plug new monitor in and install it again from the manufaturer site
Posted on Jan 03, 2009
  • 156 Answers
SOURCE: Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
Posted on May 25, 2009
  • 225 Answers
SOURCE: Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
Posted on May 30, 2009
  • 45 Answers
SOURCE: red lines on hp w1907 monitor
this sounds like pixels have died on the screen there is no cheap fix for this, its cheaper to buy a new one. if it is still under warranty bring it back as the manufacturer should cover this
Posted on Aug 07, 2009
I have a Sony KDL32D300 Digital 100HZ Lcd Tv that I bought 3 years ago for around £800. The television no longer displays a picture, just a series of vertical coloured lines that cover the entire...
Unfortunately the vertical colored lines usually indicates the lcd panel is faulty. Replacing that part is usually more expensive than just replacing the TV. If you want to try a fix there is a multi wired cable that plugs into the panel. there is a slim chance that reseatting cable on both ends could help.
Sep 13, 2010 | Sony Televison & Video
Hp dv9500 has vertical coloured lines on screen. windows starts up ok as i can hear the program sounds, but, no display
The 9500 series unit, should still be within warranty.
HP offeers an additonal year for video problems.
That means if you purchased the 1 1/2 years ago, it is still in warranty.
Contact HP customer care and get it back. ASAP.
Hope this has helped.
Sep 27, 2009 | HP Pavilion DV9500Z 17" Entertainment...
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Pink Vertical Line on HP dv6439nr
screen need to be replace. call hp support and get a RMA.
Oct 11, 2008 | Computers & Internet
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
Vertical lines o my desktop
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Vertical Lines in Monitor
I am using an Acer and my screen has over 25 lines now. Same vertical lines. Can anyone tell me what I can do to correct it??
Rasheed
Oct 07, 2006 | HP Pavilion zd8000 Notebook
HP LP2275W  22 inch Monitor Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
