Question about Nikon F65 35mm SLR Camera
Nikon F65 won't auto-focus or take shots
Hi, My old Nikon F65 will no longer autofocus. I attach the 28-80mm lens, correctly set it to 22 and lock it in position. Check the camera is set to AF and also auto. When I press to take a shot it zooms in and zooms out to autofocus, but then doesn't take the shot. This happens in all light conditions. All I get is a flashing green LCD dot in the viewfinder. The viewfinder is also a little bit blurry when viewing. The lens is clean and the camera does the same with the 70-300mm lens I have too. I've tried adjusting the switch by the viewfinder to the most clear setting possible but still no photo can be taken, though the camera will take shots when it's set to manual. I haven't used the camera for about a year and I read on this forum that it could be due to oxidisation. Is there anyway to resolve this myself or should I just take it to a camera shop to be serviced please? Any help would be much appreciated. Cheers Ian
    New Friend:
    Problem Solver:
  • 10 Answers
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Posted on Nov 19, 2017
randy320sgi
  • 121 Answers
SOURCE: re: poor focus problem
usandy,
You can set the focal point by toggling the menu switch (you can see it moving around into different locations as it "wraps" around the viewfinder, now depending on your f-stop the area that is not in focus will be soft, you can also experiment with the autofocus lock on you subject and evn try amnually focusing on your subjects.
randy320sgi
Posted on Jan 07, 2009
randy320sgi
  • 121 Answers
SOURCE: Nikon F65 power switch button issue
rads_london,
Sounds like you have been shooting in one of the manual modes, make sure if you have been trying different F-stops to change the aperture ring back to it's auto position (red numbers F-22 usually) to align with the white dot on the lens. That way the camera and lens can agree on the amount of light needed and how much the shutter will open to allow light in. The camera won't take the shot if it is way off (kind of a safety). Use the viewfinder to learn what combinations the camera needs for a particular shot so you can be familiar with the speed and aperture settings, try them in one of the manual modes and you will be pleasantly surprised with the results. Soon you won't shoot as much in auto mode.
randy320sgi
Posted on Jan 15, 2009
SOURCE: Focus issues? PLEASE HELP, need for class!!
theres a little switch to the right of the viewfinder, try moving it
Posted on Apr 02, 2009
  • 10865 Answers
SOURCE: Nikon D90 stuck on manual focus mode.
DEFINITELY return it while it iis under warranty.
Posted on Oct 01, 2009
KingDWS
  • 1606 Answers
SOURCE: Nikon N80 takes one shot, then needs abt 10 sec cooldown
If your batteries are fresh ( have seen flat new ones older stock) and are using alkalines then I would think you have a connector problem. Can you check and clean the connectiosn inside the grip and on the camera body. I've also seen dirty lens contacts and even a sticky shutter cause this. It's usually not serious just rather annoyng until you find it.
Posted on Apr 22, 2010
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
My N55 won't let me depress the shutter (to take the shot) when it's on automatic setting. I depress once (half-way) for autofocusing--which seems to work fine. No error message. But then, the N55...
Could be your lens is not communication with the body. If the lens is not telling the camera that the AF has locked on an object then it won't allow the camera to fire. Make sure that the camera is indeed locking the AF on the object. If there isn't enough contrast (for example a plain wall) then it wont be able to lock onto it. This would usually explain why it works on manual but not on auto (I assume you mean the focus setting and not the camera's modes). If you're still having issues I recommend you contact a nearby Nikon authorized service center for assistance and possible repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon N55 35mm SLR Camera
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Currently I have a Nikon F65 non-digital camera with 28-80mm lense. I am planning to buy a Nikon D5000 DSLR. My Question: If i buy a Body on D5000 and will be able to use my f65 lenses? Will there will any...
If anything, you will gain image quality because the sensor on the D5000 is smaller than a frame of 35mm film. Thus you will only be using the central portion of the lens. On the D5000, the 28-80mm lens will act as a 42-120mm would on the F65.
However, you will lose autofocus capability. The D5000 does not have a focus motor in the body, relying on the lens having the motor, and neither version of the 28-80mm lens has a focus motor. The lowest-end Nikon dSLR with a focus motor is the D90.
Feb 07, 2010 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
rads_london,
randy320sgi
Aug 18, 2008 | Nikon F65 35mm SLR Camera
Nikon Auto focus problem with the 18-135 KIT lense
I had this problem and just realised it today. I found out that it was a a settings problem. What I had done without realising was I had my "AE-lock" button functioning as "AF-ON" which meant that my autofocus would only turn on when I held the shutter half-way and pressed that button. Once I turned this function back to its original state of "AF-Lock" as opposed to "AF-ON", it worked fine.
My symptoms were: • soft mechanical noise when holding the shutter (i thought it was trying to focus but couldn't. I thought the mechanics for the AF were faulty) • Couldn't take photos unless they were in the set conditions (which makes sense because it was locked on a certain setting until I pressed the AF-ON button).
My camera is only a few months old so I wasn't convinced it was faulty/broken. Make sure you test all of your settings and go through each of them before you chalk it down to equipment error.
Hope this helps.
Dec 03, 2007 | Nikon D80 Digital Camera with 18-135mm...
Auto-focus isn't working
Try checking your settings for the type of shot you are taking and for the type of focus......
type of shot is the dial on the top, and then:
1) menu, metering
and also check your autofocus mode
2)menu, autofocus; try the single autofocus, it might be set to continual
Also, you could try updating the firmware in your camera. You do this through the Nikon website.
Jan 23, 2007 | Nikon Coolpix 5900 Digital Camera
Nikon F65 35mm SLR Camera Logo
263 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
