Question about AEG Washing Machines
AEG lavamat 16850 not drying - AEG Washing Machines
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
AEG Lavamat 16850 shows err (some kind of error code) anyone know how to restore to factory settings?
suggestion, ring up AEG and ask for the technical department
give them model and code and they should give you the answer your looking for good luck.
Oct 05, 2016 | AEG Washing Machines
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Lavamat L 16850. It has stopped showing an EFO error code for the second time (on the 20 minute cycle both times). The first time I removed the fluff filter which seemed to solve the...
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
Oct 25, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
