Question about Samsung HT-X20 Home Cinema 600W Theater System
Samsung ht-ds110 protetion masses then power off
Protection masses after system off
SOURCE: Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Posted on Jul 02, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
  • 25 Answers
SOURCE: samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Posted on Aug 26, 2009
johex
  • 75 Answers
SOURCE: Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Posted on Mar 14, 2010
Samsung HT-TZ312 Stereo System flashes protect and turns off
Turn the unit off.....reseat connector at the power board (supply).After reseating, turn it on again and the protect error will disappear....I have this problem after repairing the optr16 power supply that accidentally plugged into 220v...only the 5q1265rf (power switch)and 9v zener diode connected at optocoupler being damaged. Hope this helps! Mhar fernando from the Philippines
Nov 26, 2010 | Samsung HT-TZ312 Theater System
I own samsung home theatre code no: ht ds110 n. can i be able to play the audio output through samsung tv wthout connecting 5.1 speakers. please reply for that and guide me.
You probably could if your TV supports external audio. Refer to ITs manual. It would be limited by the audio capabilities of the TV, most likely stereo.
Again, see the manual.
Aug 08, 2010 | Samsung Audio Players & Recorders
Power ON
Mar 14, 2010 | Samsung HT-Z210 Theater System
Samsung HT-TZ312 shows "protect" and it turns off
A short on the speaker wires can cause this but most likely your amplifier bias is off or you have a shorted transistor.
First unplug all connections, even the power. Let it sit for a minuit then power it back up.
If it clicks off them it needs professional service.
If it turns on inspect all of your speaker wires for shorts them reconnect them one at a time.
Hope this helps,
Cheers
Feb 03, 2010 | Samsung HT-TZ312 Theater System
Powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Jun 30, 2009 | Samsung Audio Players & Recorders
When powered up, it states "protect" and shuts down.
it is a known product defect. samsung will fix it for you if you send them a lot of money. this helps them keep their prices low.
May 25, 2009 | Samsung HT-Z310T Theater System
I see'protection' then it turns off
Protection means the unit is detecting a short somewhere. Disconnect speakers and components and attempt to power on the unit again. If it will power on with nothing connected, repeat the process (turn off, connect something, then power on) until you find the bad component or speaker.
Dec 31, 2008 | Samsung HT-DS100 System
Samsung dvd home cinema system ht-ds110 not playing dvds
My initial IDM-1731 tells me no disc every time i try to play dvd cd please help me
Jan 06, 2008 | Televison & Video
Dsp protection
Resetting- taken from the user manual:
Jan 27, 2006 | Samsung HT-DB600 System
Samsung HT-X20 Home Cinema 600W Theater System Logo
107 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
