Question about Dryers
Creda Simplicity T620CW Tumble dryer. Switches on ok – gets warm (don’t think its getting too hot) and runs for a few minutes then shuts off. Cleaned filter etc. Can someone point me in the right direction? I was thinking thermostat’s (there are 3 – two near the heater and 1 near front door) or relay above door. Any help appreciated and gratefully received. David
Timon90
  • 126 Answers
SOURCE: tumble dryer
Check the thermostats. Could also be a reset-able overheating thermostat that needs to be reset.
Posted on Jan 28, 2008
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
barkencoa
  • 3463 Answers
SOURCE: No hot air from my tumble dryer
Hi.
You do not state whether it is a condenser or vented dryer.
the most obvious reasn for no heat is element and/or stats..
The only way to confirm which it is-- is to meter them out with a multi meter..
If you have one then set it on the ohms range and test the components for continuity, you should get full scale deflection if they are o/k.
You must disconnect the wires to the components, or you will get a false reading, and needless to say, have the m/c unplugged.
If all test o/k then the problem could be with the timer and or control unit, or the heater relay if it has one.Unknown to me as I do not know your model number.
If it is a condenser dryer, make sure all filters are clear, air intake and outlet vents clear, water container empty .
Plz rate my solution
Thanks
Posted on Dec 29, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Posted on Apr 09, 2009
  • 142 Answers
SOURCE: How do I replace the belt on my Creda T620CW
most credas you need a stretch tool to stretch the belt from drum to motor if there is no jockey pulleys good luck.
Posted on Sep 14, 2009
I want Creda simplicity T620CW manual
Try Googling (creda)(T620CW)(manual) without parens.
Jul 03, 2017 | Creda Washing Machines
Creda simplicity dryer
new interlock then .....cheers
Jan 30, 2014 | Dryers
Hi I have a Creda Simplicity TVR2 tumble dryer, the drum is rotating ok but it doesnt get warm air going through it. the drying process takes a lot longer than usual. Is this something we can repair...
hellojean, the problem may be down to the heat sensors these's usually 2 of them and they are located at the back of the dryer with wires attach to them.you need some 1 with a multimeter to test them if 1 is faulty change both of them.if theses are ok the the element is the next thing to test hope it helps
regards
shaun
Sep 20, 2011 | Dryers
WE HAVE REPLACED HEATING ELEMENT. AND THERMOSTATS. ON A CREDA T620CW TUMBLE DRYER. AND STILL NOT HEATING UP.ANY IDEAS PLEASE.
Reset overtemp thermostat should be small round disk attached to drum with a little red button.. Press firmly should reset ..
Feb 28, 2011 | Dryers
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Jul 05, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
How do I replace the belt on my Creda T620CW tumble drier
Sep 14, 2009 | Dryers
Creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Jul 26, 2008 | Dryers
Tumble dryer
Jan 20, 2008 | Dryers
Dryers Logo
160 people viewed this question
Top Dryers Experts
