Question about Zanussi Ovens
ZANUSSI ZOD685X WENT POP NOW MAIN OVEN HEATING BUT DOESN'T STOP AND GRILL NOT WORKING AT ALL
WHILE USING THE FAN OVEN IT WENT POP THEN THE FAN STOPPED WORKING AND JUST KEPT HEATING. I HAD TO TURN OFF AT THE MAINS TO COOL DOWN. WHEN I SWITCHED BACK ON THE MAIN OVEN WILL HEAT AND HEAT BUT THE TOP OVEN/GRILL WON'T COME ALL AND NOR WILL THE LIGHT. COULD YOU ADVISE WHAT MAYBE WRONG?
  • 4 Answers
SOURCE: Grill problem
YOUR PROBLEM IS WITH THE GRILL SELECTOR SWITCH REPLACING THIS WILL CURE YOUR PROBLEM.
Posted on Feb 14, 2008
SOURCE: Main oven not working
element needs replacing
Posted on Mar 14, 2008
SOURCE: Main Oven does not get
Called Engineer in the end, Heating element needed replacing
Posted on Aug 15, 2008
barkencoa
  • 3463 Answers
SOURCE: Fuse blew on opening main door; main oven not heating; everything else ok
I agree with earlier diagnosis.
It will be the fan element blown.
Posted on Nov 28, 2008
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
Fan and element not working
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
Zaunssi ZBF360X built in Oven Not Heating
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Zanussi zbf 760 (9 yrs old now)
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
52 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
